This is my official motor swap thread - PICS ADDED!!! - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
Old 10-09-2018, 08:22 PM
Rumble phish
Rumble phish is offline
Rumble phish is gaining momentum as a positive member of FTE.
Hopefully it won't go 300+ posts!
Just got my motor in from Fraser Engines. Looks good. Had my mechanic pull the valve covers so we could look at the cams and valve train. Nice and shiny. However, even though I specifically asked if the cam and cam towers were stock, i.e. no "custom" cam bearings installed, there they were. I suppose it's not that big of a deal, but it's a little annoying.
Something I've learned about remanufactured motors is there are only a couple of actual manufacturers. All of these places you see selling the motors are just middle men and installers. Seems Fraser Engines got my engine from AER Manufacturing. AER remanufactures for OEM (Ford, GM, Nissan, etc). The motor looks to be of high quality, but I suppose we won't really know until it has a few thousand miles on it. I've decided to bite the bullet and replace everything I can while it's out of the truck. I'll be picking up a new intake manifold and an AC compressor kit (compressor, drier, valve, o-rings, and condenser). This is basically going to be a brand new truck under the hood.
I'll post up pics as we go along.
Old 10-12-2018, 03:30 PM
Rumble phish
Here are a few pics of the motor I received from Fraser Engines. I was able to verify that the phasers and VCT solenoids were genuine Motorcraft parts
Old 10-12-2018, 03:31 PM
Rumble phish
Old 10-12-2018, 03:32 PM
Rumble phish
Old 10-12-2018, 03:37 PM
Rumble phish
One thing I was disappointed in was that the water pump that came with my motor was a Duralast (Autozone) water pump. WTF? I'm going to skip that and put a Motorcraft water pump on it instead. The oil and filters they gave me were the cheapest ones you could get at Autozone (STP). I'll use the oil for break in, but I'm using a Mobil1 oil filter. The air filter will be good enough though. After break in I'll be using Castrol GTX semi-synth 5w-20 exclusively.
Old 10-20-2018, 06:14 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.70f100longbed has a great reputation on FTE.
How is the swap going? Did they lift the cab or pull it from the top?
Old 10-27-2018, 08:41 AM
D8chumley's Avatar
D8chumley
D8chumley is offline
Resident smarta$$
D8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud ofD8chumley has much to be proud of
Subscribing
Old 10-28-2018, 06:12 PM
Rumble phish
Slowly
It's going slowly. The mechanic got the motor pulled the old fashioned way, through the top. As he was pulling it, the heater hoses fell apart so I had to get those. Seriously, nobody carries the inlet hose! So, since we had to wait for the hose I went ahead and ordered new cam position sensors and a crank position sensor. I also went ahead and ordered a new starter.
​​​The mechanic has to be out in Idaho next week, so the new engine doesn't go in until the week after. Luckily, I'm not in a hurry.
Old 10-29-2018, 09:54 AM
Rumble phish
Here's a picture of one of the cylinder heads on the engine that we pulled. Can you see the major problem here?
Something's wrong here. Can you see it?
Old 10-29-2018, 09:56 AM
Rumble phish
Who paints the valve train?!
They even painted the valve springs!!! :-O
Old 10-31-2018, 05:56 PM
3Prcntr's Avatar
3Prcntr
3Prcntr is offline
3Prcntr is starting off with a positive reputation.
If it's a factory engine, then FORD painted it... which given the year and engine, would not surprise me.
I had a reman put in mine and I'm only 2k miles into it. Ticking is still there and I'm pretty sure there is a head gasket leak. Did my oil the other day and found a milky froth on the oil cap, plus the coolant was low. Really hoping it was condensation and temperature changes but the coolant.... worries me to say the least. I've been using 5w-30 motorcraft syn blend, and filter. I swear I'll drive this truck off a cliff before I sink another dollar into it.
Old 10-31-2018, 08:05 PM
Rumble phish
Well, the engine that came out of this truck was definitely not the original. My mechanic is stumped as to why anyone would spray paint the valve train. They even painted the camshafts!!! I seriously doubt it was Ford who painted it .
Sorry to hear of the issues you're having with your remanufactured motor. Who did you get it from, and who installed it? Hopefully it's under a decent warranty.
Old 11-08-2018, 08:59 PM
Rumble phish
Stopped by the shop today. No progress on my truck, which was a bit disappointing. The mechanic said the heater lines came without the quick connects so he had to order them, which delayed the progress. He also had to complete a few other jobs in the mean time. I'll admit that I'm becoming a bit antsy and frustrated, but I want this done right the first time. Patience is a virtue, or at least I keep telling my self that...
Old 11-08-2018, 09:55 PM
70f100longbed
The frustration is understood. Independent shops need to move cars in and out to pay the bills they don't have the reserve capital like a dealership. I have ran into the same situation at my shop it's the first independent that I have worked at.
Old 11-13-2018, 11:02 PM
Rumble phish
Exhaust?
Motor is going in tonight/tomorrow. Hopefully it'll be running by Thursday. One thing that was discovered when the old motor was pulled was that the passenger side cats were fairly plugged. It looks like ilI' have to replace it.
So I'm thinking of just doing the whole exhaust system from the manifolds back. What kind of cost would I be looking at? $1000+? Any suggestions on type and/or brand?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
