Help with forscan with bed lights asap - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 10-09-2018, 07:59 PM
Genenj89
Genenj89 is offline
Genenj89 is starting off with a positive reputation.
added oem bed lights. Made changes in forscan. All worked well. Turned on turned off. Switch worked great. Went to turn them on. They clicked on for a second and the shut off. Now no power at wires for them. Ideas?
Old 10-09-2018, 10:55 PM
rsgates's Avatar
rsgates
rsgates is offline
rsgates is starting off with a positive reputation.
fuse. Can you figure out what circuit they're on?
Old 10-11-2018, 01:59 PM
Genenj89
Genenj89 is offline
Supposedly there’s no independent fuse for them. Anyways. The up top cargo lights still functioned. Was only lower ones. I ended up checking them again like 15 mins later and they were working perfectly. Kinda confused.
Old 10-11-2018, 03:21 PM
mhoefer's Avatar
mhoefer
mhoefer is online now
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
I cant find the control series in the BCM for the running boards, nothing noted in the spreadsheet, nothing in my BCM cause I dont have these. So, its a needle in a haystack sorry.
Old 10-15-2018, 04:24 PM
Genenj89
Genenj89 is offline
Still confused on this. Cargo lights hVe all been working fine for a few days. Turned them on today and the bed lights only went on then clicked off within 2 seconds. Up too lights stayed on. Went to store, came back. Clicked on lights from bed switch. They worked fine. Shut them off. Clicked them back on. They went on and shut right back off again. Wtf is with this thing...nice brand new truck
Old 11-16-2018, 10:03 AM
wasitim
wasitim is offline
wasitim is starting off with a positive reputation.
Geneh89, can you share the part number for the light kit? Thanks
Old 11-16-2018, 10:32 AM
BIGDOG1974's Avatar
BIGDOG1974
BIGDOG1974 is offline
BIGDOG1974 is starting off with a positive reputation.
Can a FORSCAN adjustment allow for the rear cab mount camera to be viewed while driving over 6mph ?
It would be nice to check the contents in the bed while driving down the road on occasion.
The New Fiat Ram allows in motion camera usage I believe.
Old 11-16-2018, 10:34 AM
6.2caribou
6.2caribou is online now
6.2caribou is starting off with a positive reputation.
Did you plug the kit into a factory connection point or did you tap into the truck's wiring via a Scotch lock type clamp on connector?
Old 11-16-2018, 10:44 AM
GABAR
GABAR is offline
GABAR is gaining momentum as a positive member of FTE.GABAR is gaining momentum as a positive member of FTE.
Go to the Ford Accessories website and look under bed cargo accessories for your model and year truck.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
