Budget build plan for 72 390
Thanks guys for the feedback. I had though about the 500 awhile ago but now that you guy bring it up it may be the best option at this time.
I used to have a Holley 500 on my 77 bronco's 302. It ran very well on the street and passed emissions, but was a completely useless turd off road. Had to go back to the 2100 but I knew fuel injection was the only real solution.
So in went a roller 5.0 from a 91 mustang but it had a few weak holes so it snowballed into a 347 stroker with trick flow heads, FI intake, big MAF, TB, injectors, etc. Then that lead to a fully built C4, 456 gears, Detroits, chromoly axles, and so on. So ya I've been down that path...
Engine plus conversion mounts, different transmission, different exhaust, possible oil pan mods, an extra 100+ lbs on the front of the truck.
yup. but I can weld my own mounts. No factory married transfer case FE C6 so would have to build one from 2, as I don't want to sink money in a divorced setup. Exhaust has to change anyhow. Ford put 460s in 2wd dents so oil pan, headers and other items are available. Get 70 more cubic inches without buying a stroker kit. Used Parts are less expensive and much more readily available. There are good and bad about both FE and 385, I like them both. If I wasn't converting to 4WD I would have stuck with the FE.
460 is lighter weight from my searches. but yes a NP205 and a dana 60 will add weight.
marquer
10-10-2011 06:22 PM
bad_behavior
15
03-04-2011 05:40 PM
Bigfoot76
05-29-2010 12:22 PM
390fe
08-03-2004 06:05 PM
