walbro 255 gph gas pump - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-09-2018, 05:20 PM
BigDan1
BigDan1 is offline
BigDan1 is starting off with a positive reputation.
I want to install a Walbro 255gph gas pump to replace my aging original gas pump
bought the walbro with my 1996 E350 7,5L ( 460 ) in mind .....they sent me what is supposed to be a direct replacement
removed the gas tank , removed the original pump ,it does not look the same at all ....Unless the pump itself is hidden under the big cover
anyone knows ?
thanks
Dan
Old 10-10-2018, 05:32 AM
JWA's Avatar
JWA
JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Curiosity drove me to Walbro's site---good gravy are their installation instruction woefully lacking any info about actual installation of their parts.
Would a good quality OEM fuel pump not be the better way to go with this?
Old 10-10-2018, 05:37 AM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
wiskeyVI is starting off with a positive reputation.
I would think that screen was snapped to the pump, but I cant imagine it being in that housing, but it may be.
Old 10-10-2018, 09:03 AM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Yes the actual pump is inside that tan colored resovoir and it can be dismantled, when I tried to do this upgrade the 255gph was too long and wouldn't fit but that was quite a few years ago so maybe there is a pump that will fit now.
Old 10-10-2018, 06:00 PM
BigDan1
BigDan1 is offline
finally ,
after some fooling around , I did it
yes the pump is inside the plastic housing
problem : the walbro is about 3/8" longer , I had to cut down the bottom seat by that amount
it went in easy after ,,,,,
quite simple , beside getting the housing modified
now 255 gph .....:-) should suffice for the moded 460
thanks
Dan
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
