Fox ATS Stabilizer vs Standard Fox Single Stabilizer
#31
#32
Because most dual kits require a lift
Because dual stabilizers are not necessary and don't work better than one
Because they are right in the 'get smashed by a rock' zone
Because they look like the 90s trucks that had 10 shocks per corner for no reason
Because ATS is adjustable
Because it was purpose built as a stabilizer, and has no nitrogen chrage directional biasing (though neither should a properly set up single stabilizer)
#34
Ok now I'm pissed. I talked to Desert Rat today, who said Fox emailed them, and told them they are actually out of stock, and that my order will take six weeks. W-T-F. It took them over a week to figure that out? Remember, Fox told Desert Rat when they ordered my stabilizer that they had 3 in stock. I am really fed up with Fox and their disorganization. Total Busch League inventory tracking. How can you get a different answer every day of the week from each rep there? Are they not using the same damn inventory system? I am this close to buying a King product instead.
#35
#36
#37
Cool story. No way would I buy a slide in camper. To each their own. If you want a purpose built adjustable stabilizer, then you spend $440.
#41
Made it home with some day light. 15 minute install. You do need a buddy or wife to help you out. The steering wheel has to be held at full max to the right to mount the clamp (with 1/8" of shaft showing at that point). Set it to "12" of 24 settings to start. Didn't go on a drive, just backed it back up into the driveway - it did make the steering feel a little more sturdy than it was. So I will play with adjustments. I also did have to rotate the reservoir to avoid it from hitting anything. Easy adjustment - just an allen bolt on the L bracket clamp to rotate it.
#44
#45
https://www.tascaparts.com/oem-parts...RpZXNlbA%3D%3D
