late-model 4cyl in an old econoline?
Welcome to FTE.
Sure, you can do that. You might save some gas, but it would be hard to save money doing it.
You have a shop, welder, donor car?
And:
https://www.scs-delta.co.uk/ford-ecoboost-ecu
And:
Rearend ratios for diesels are the same as gas engines. My 99 SD F250's rear is 3.73. And speakin of 4 bangers, I drove a Dodge Ram van last year to Kansas, coulda sworn it had a hemi in it. It wasn't. It was a big 4 banger that if doubled added up to a 500+ inch V8. And got 17 mpg on the highway doin 75 . If it weren't so butt ugly, I'd a thought about buyin one.
Axle ratio would be 3.50 or higher numerically, even a 4.10 would be possible.
Even with a balance shaft, aren't those motors a real shaker? Especially when it's at your elbow?
An E200 is either going to be a Ford 303 3 on the tree, or a C4 automatic. The old 4BT and 6BT Cummins are pretty smooth running, they only shake allot on shutdown.
A good built E4OD/4R100 transmission with a stand alone PCS controller would probably be the best option but not cheap.
So, a 4BT to GM auto would be easy, but OP would probably have to step up to a later, stronger, electronically controlled transmission.
And then there is Dodge. A 47RH/RE from behind a 6BT in a Dodge pickup would work.
Nowhere do I find the words "cheap", "easy", "inexpensive", or anything else leading me to believe that the OP would be well served going down any of these roads.
