Electrical or something to look into - Oil Pressure - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009 - 2014 F150
Reload this Page >
Old 10-09-2018, 07:26 AM
tractorboy924
tractorboy924 is offline
tractorboy924 is gaining momentum as a positive member of FTE.
I have a 2012 FX4 5.0L coyote with 182,000 miiles and I have had some instances lately that make me wonder. My oil pressure guage only goes down (like you shut the truck off) to low....warning messages comes on and then a second later the oil pressure goes back up normal. Im thinking this is more electrical. Its ONLY the oil pressure guage no others..but I think the oil pump is mechanical on this motor I have to investigate. I now have a CEL on and need to get it read. Im wondering if this could be a guage issue or if I may be having oil pressure issues? I have to check my oil level to make sure Im full. I have no low oil level light or anything but just to be sure. It does not seem to happen during any specific instances like when slow speed or stop or anything its totally random. All other guages are normal;engine temp is "normal" and not any higher than usual as I know that can be a sign of bad oil pump.
Like I say tonight I will check my oil levels as I have notice lately I think I may have developed an oil leak but I want to make sure I may not be truly having oil pressure issues?!
Thanks for any help advise in advance
Old 10-09-2018, 10:25 AM
alloro
alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
Could also be the oil pressure sensor.
Old 10-09-2018, 10:27 AM
tractorboy924
thats what im thinking more than anything but hoping someone might have some experience with it. Thank you for the input.
Old 10-11-2018, 10:28 AM
tractorboy924
ok figured it out..helps to have proper amount of oil in there to have pressure. I added like 3 quarts...shes has developed an oil leak I dont knw where it is yet I have to look. but oil all sprayed under carraige.
It must only leak when running as I dont have oil spots under where I park!!!!! so much leak only when driving. what areas are notorious on these motors for oil leaks.
Gotta get under her and clean it up as oil all over and see if I can see where its coming from to fix it!!!!!!!!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
