Any Forscan members?
Make it easy on yourself. Pull the passenger side fuse panel cover and look up in there to see the code written on the box.
Or if you have 2 admin keys
If either of those do not work I can help with forscan too.
- Insert the FIRST KEY in the ignition
- Turn to the “on” position but do not start the engine, and wait about 4 seconds
- Turn the ignition key to “OFF” position
- Take out that key and then insert the SECOND KEY
- Turn to the “on” position but do not start the engine, and wait until your factory code show up on the dash screen
Dead Truck
01-25-2011 01:33 PM
