Glow plug ses light bypass? - Ford Truck Enthusiasts Forums
Old 10-08-2018, 12:28 PM
Tormz
Tormz is offline
Tormz is starting off with a positive reputation.
Is there any way to add a resistor or some this to bypass the ses light. I have a e99 that has codes for the glow plugs on both banks but they work fine. They all ohem good. Valve cover gas kits are only a year old and I installed the large white Rodgers relay. Ses light still just stays on and would hate for something that needs to be addressed come up and be overlooked thinking itís still glow plugs. Thanks in advanced
Old 10-08-2018, 12:39 PM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
Have you tried clearing and resetting the codes?
Old 10-08-2018, 12:47 PM
Tormz
Tormz is offline
Yes I have reset them. They will come back on within a few days.
Old 10-08-2018, 11:41 PM
viperman86's Avatar
viperman86
viperman86 is offline
viperman86 is starting off with a positive reputation.
does your truck have a GPCM ? aka CA truck
Old 10-09-2018, 12:00 AM
Tormz
Tormz is offline
It is a ca truck however I only have the strut between both bankes on the replay
Old 10-09-2018, 03:53 PM
Tormz
Tormz is offline
Or any one have any ideas what else it could be.
Old 10-09-2018, 04:01 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
Did you transfer the shunt to the new relay? If not, you will always have those codes. The only workaround is to use a PCM from a federal E99 otherwise.
Old 10-09-2018, 04:26 PM
Tormz
Tormz is offline
yes I did reinstall the shunt.
Old 10-10-2018, 03:38 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
Then your wires are crossed somewhere. There are 5 wires on the GP side of the relay. One small one goes on the main post of the relay. The two big ones go on either side of the shunt and one small wire on each side of the shunt. The PCM is monitoring amps at each of the 3 wires. It expects to see a difference between the one on the main post and the two on the shunt. That is how it verifies the GPs are working on either side. If the amps are equal it triggers the code you are getting. Since you are getting codes for both sides, it is either a dead relay or bad wiring.
Old 10-10-2018, 08:43 PM
Colorado350
Rest of the free world
CA
Old 10-11-2018, 10:15 AM
Tormz
Tormz is offline
Hereís what I got.
Hereís what I got.
Old 10-11-2018, 03:10 PM
Hussler's Avatar
Hussler
Hussler is online now
Hussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to beholdHussler is a splendid one to behold
I can't see a wire on the center terminal on the strap. With the picture provided the best I count is 5 wires on the GP side at about 11:00 o'clock position and maybe 6 wires on the the GP side at about 2:00 o'clock position. That center wire on the strap is important because the PCM uses it as a reference voltage. If that is the case then one of those wires needs to be moved to the center bolt strap from the 2:00 o'clock position wiring to the center strap bolt. It's probably one of the wires that have been extended , but don't know for sure. You might need to cut back into the harness assembly a bit to find the true color code.
Old 10-11-2018, 05:49 PM
coax9952's Avatar
coax9952
coax9952 is offline
Athletic Supporter
coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.
Not to mention that is not a shunt strap, that is a Piece of tinfoil made to look like a shunt.......You try to pass any kind of amperage thru that and you're gonna let some smoke out, just sayin.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
