92 E350 Cutaway Rv Evap Vent Valve - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-07-2018, 11:06 AM
Maddog10
Maddog10 is offline
Maddog10 is starting off with a positive reputation.
Hi, we have a 92 e350 cutaway rv with 7.5 steel rear fuel tank. Looking for a replacement evap vent valve F2UA-9B593-AA or equivalent or modification as cannot fuel tank due to excessive pressure. Thx in advance.
Side view 2 ports on the top
Fuel tank
Valve top 2 ports on the right
Old 10-07-2018, 01:25 PM
JWA's Avatar
JWA
JWA is online now
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
If that's a definite part number here's one or more:
F2UA-9B593-AA F2UA-9B593-AA
Double-check the application as the number you've provided might not be a part number. It does appear to be Ford's numbering scheme however.
HTH
Old 10-07-2018, 05:25 PM
Maddog10
Maddog10 is offline
Thx. That is the number on the valve and it appears to be a ford part. It has 2 ports and the one in your link is single, will this work or does it have to have 2? Also just wondering if it is going to lock properly in the steel tank. Thx kindly.
QUOTE=JWA;18236617]If that's a definite part number here's one or more:
HTH[/QUOTE]
Old 10-08-2018, 05:45 AM
JWA's Avatar
JWA
JWA is online now
I have no idea really---completely not familiar with that year, simply did a Google search using the number you provided.
Perhaps check RockAuto or a local Advance Auto, NAPA etc etc.
HTH
Old 10-09-2018, 05:36 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Hi, we have a 92 E350 7.5L steel rear fuel tank.
Looking for a replacement evap vent valve marked with ID engineering number: F2UA-9B593-AA
This is not the part number!
NO Ford part numbers marked on parts after 1956, just casting or ID engineering numbers, when applicable.
F4UZ-9B593-F (replaced F2UZ-9B593-A) .. Two Port Fuel Vapor Valve / Marked: F2UA-9B593-AA / Obsolete
1992/96: E150/350 5.8L (351W) & E350 7.5L (460).
No Ford dealer or obsolete parts vendor has any. Try NAPA or an indie auto parts store.
btw: The F2UA-9002-EE number on the fuel tank is also an ID number, it is not the part number!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
