walbro 255 gph gas pump
I want to install a Walbro 255gph gas pump to replace my aging original gas pump
bought the walbro with my 1996 E350 7,5L ( 460 ) in mind .....they sent me what is supposed to be a direct replacement
removed the gas tank , removed the original pump ,it does not look the same at all ....Unless the pump itself is hidden under the big cover
anyone knows ?
thanks
Dan
anyone knows ?
thanks
Dan
finally ,
after some fooling around , I did it
yes the pump is inside the plastic housing
problem : the walbro is about 3/8" longer , I had to cut down the bottom seat by that amount
it went in easy after ,,,,,
quite simple , beside getting the housing modified
now 255 gph .....:-) should suffice for the moded 460
thanks
Dan
thanks
Dan
Kwikkordead
52
03-17-2006 02:54 PM
jake00
General Automotive Discussion
21
11-10-2005 07:16 PM
F150Texan
46
07-17-2004 01:19 PM
