engine fuel filter stuck - Ford Truck Enthusiasts Forums
Old 10-07-2018, 10:04 AM
Dutchy1857
Dutchy1857 is offline
Dutchy1857 is starting off with a positive reputation.
My engine fuel filter is stuck. Ihave the new one in and seated but cant turn it in the housing. Can I remove the housing so i can work on it better 6.7 diesel of course
Old 10-07-2018, 10:13 AM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
I had to use a large pair of channel locks to turn mine. Next time I'll spray some silicone lube on the body.
Old 10-07-2018, 10:23 AM
Dutchy1857
I lubed it with a bit of oil as i was doing a oil change at the same time dont have a large enough pair of pliers so thought of removing the housing.
I don't know if that will screw any thing else up.
Old 10-07-2018, 11:13 AM
Dutchy1857
Thanks 69cj Your reply got me thinking , I have a die cast machined oil filter wrench and it fit perfectly on the old filter. I used it and worked like a charm. Just have to remember it for next time. Got to go time to order more filters. Thanks again
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
