Deleted truck - exhaust filter warning - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 10-06-2018, 08:00 AM
bcg
bcg is offline
bcg is starting off with a positive reputation.
I have a fully deleted 2014, yesterday I got a message on the display that says "Exhaust Filter Over Limit Service Now" driving home and boost was limited to no more than 10psi. I'm guessing there is a problem with my tunes but, I can't get in touch with anyone about that until Monday. Is there a way to reset whatever caused this message with ForScan or something in the meantime?
Old 10-06-2018, 01:59 PM
UP_There's Avatar
UP_There
UP_There is offline
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
Your tunes are supposed to be setup to completely ignore and over-ride all things related to the delete. Definitely something is missing on the tuning end of things. I don't think you can clear that code. The computer is recognizing that it's gone
Old 10-07-2018, 07:36 AM
bcg
bcg is offline
That's what I thought. The message was gone when I got in the truck yesterday morning and it ran and drove fine. I think there are some tune issues though, I'm getting a recurring code in some of the "higher" settings on the SOTF, it occasionally shifts hard enough that it feels like someone did it with a sledgehammer and now this.
Old 10-07-2018, 09:16 AM
The Bone's Avatar
The Bone
The Bone is offline
The Bone has a good reputation on FTE.The Bone has a good reputation on FTE.
I took stuff off my truck and now it isn't right
Shocking.
Old 10-07-2018, 09:31 AM
bcg
bcg is offline
Shocking.
Actually, I bought the truck without this stuff on it and the tune that it came with didn't have the issues that are showing up now. I thought the shifting was a little sloppy and wanted to know how it was tuned so I bought some Tyrant tunes and that's when these issues started popping up. So, it would seem that the issues are the tunes and not the missing stuff. However, I would like to sincerely thank you for your snarky comment, I found it most helpful.
Old 10-07-2018, 08:12 PM
cappa
cappa is offline
cappa is gaining momentum as a positive member of FTE.
You need to get ahold of tyrant if that's who's tuning your running. Tyrant is usually really good and you definitely should not have any filter issues or de-rate due to the super restrictor, that's assuming it's no longer there. Get your tune figured out and this thing will be a reliable beast, way better than with that crap emission system in line, usually that is where most of the problems with these trucks occur. That and valves on the early job 1 2011's. Make sure you have the proper delete tune and let it get a bit of a relearn on the trans before you beat on it to hard, and turn it down if your towing heavy and that thing should last forever.
Old 10-09-2018, 06:42 AM
The Bone's Avatar
The Bone
The Bone is offline
I just hate it when people buy trucks then take all the stuff off thinking they arer improving there truck at the expense of the air we breath.
Ya my comment was a little snarky and now that I know more , sorry
This is the reason I won't buy a modified truck or car. I have modified cars but I also have all the parts to return to stock and I never remove pollution control stuff.
When you tune any vehicle. You take the stock tune out of the computer and replace it with a new system. Without the tuner you can't return the truck to stock or modify the tune in the truck. Not sure if the tuner came with the truck. Tyrfant may not be able to help if they sell tuners to lots of people because the tuner is locked to your truck.
You may have to buy a new tune and take the truck to to a dealer have them upload stock tune than you can start all over fresh.
Sorry you are having these issues. In the future i will try to be more helpful here.
Old 10-09-2018, 07:09 AM
bcg
bcg is offline
Thanks for that, I appreciate it. I'll admit though, the deletion is one of the reasons I bought the truck, with 163k on it when I bought it, if it hadn't had emissions problems, it was due. I live in a county with an average of about 10 people per square mile and drive less than 15,000 miles per year so my addition of soot (which I'm working to completely eliminate with tuning) or NOx will only hurt wildlife, if anyone at all. I'd rather still be in my 7.3, to be completely honest but, someone else made that decision for me when they plowed into me from behind at 70 MPH while I was turning onto my road. It's possible for a well tuned truck to run pretty cleanly without the emissions, not necessarily NOx but, I promise even with my deleted truck, the air at my house is cleaner than most places and "the solution to pollution is dilution," right? In all honesty, I think diesels are clean even without the emissions, their NOx emissions without any controls are only slightly more than a gas engine with a catalytic convertor (Vehicle Emissions | Air Pollution | City Diesel | LPG | CNG). At this point, we're reducing fractions of fractions but, we're also burning more fuel (emissions systems definitely reduce fuel mileage on diesels) and sacrificing reliability to do so. That's my position on it anyway, it differs from yours but, at least I can defend it.
There was no tuner with the truck when I got it, I bought an SCT X4 with Tyrant tunes on it so I would know what was on it and could control it and because I was seeing a small puff of smoke every time I started moving from a complete stop that I wanted to eliminate. Also, the shifts were mushy with the tune that it came with and I needed that fixed. I think the problem is that they made some assumptions about how the delete was done and programmed to look for sensors that might not be there anymore or vice versa so, I need to crawl under the truck and see what's actually still left.
Old 10-09-2018, 10:56 AM
cappa
cappa is offline
Sounds like you have it figured out. Sct or tyrant might have a oem stock tune for your truck as well and it could save you a dealer re flash. I know spartan does cause I have one. I would however take it to the dealers lot when you try and return to stock and then load the new tyrant tunes just in case the ecu locks up for some reason and you need ids to return to stock, might save you a tow as the truck will be useless until you get the proper delete tune loaded. This does go against my normal process of flashing thou as I always have a battery charger hooked up when I flash as lower battery power can cause the same issues. This is also why I turn all lights off, as well as climate control and radio, don't open any doors or use Windows while it flashes. Good luck.
Old 10-09-2018, 02:26 PM
MG250
MG250 is offline
MG250 is starting off with a positive reputation.
Not exactly a chump change fine. This may be the tip of the iceberg...or not.
EPA Fines Tuning Company $300,000 for Producing and Selling Emissions Defeat Devices - The Drive
Old 10-09-2018, 04:42 PM
jav_eee
jav_eee is offline
jav_eee is gaining momentum as a positive member of FTE.jav_eee is gaining momentum as a positive member of FTE.
Trumps working on changing that haha
Old 10-09-2018, 06:23 PM
cappa
cappa is offline
Not too worried about it in my neck of the woods
Old 10-10-2018, 08:25 AM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
Thats chump change compared to what Edge and H&S paid about 6 years ago. I had my 6.4 tuned back then and paid attention to this stuff. Heed what someone above said, tune it back to stock to tow heavy. I knew that but forgot what tune my H&S was in and blew a Head Gasket towing my big 5th wheel over monteagle $5000 plus for the repair.
Old 10-10-2018, 06:14 PM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
Edge was $500k plus $157k to apparently fund advancements to wood burning stoves. H&S settled for $1M to CARB plus $400k for the same wood burning stoves project, agreed to destroy devices and not provide support.
https://www.arb.ca.gov/enf/casesett/hands.htm
Between fines and changing encryption on vehicle modules, I think direct tuning will be very difficult in five years or less without replacing OEM modules with custom modules and firmware.
Old 10-10-2018, 06:29 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
Tell you the truth I havenít felt the need to tune the 6.7. My 6.4 was an 08 and it needed tuned. Was slow spooling up, made oil like crazy and just seemed constipated. With the tuner even in stock tune it was a beast. I blew the HG in monteaglw TN and towed my trailer 16k +/- all the way to western montana and then to yellow stone and back home. Only way I could tell the HG was blown was coolant usage. I might still have it except i got hit and totaled. I drove the 14 off the lot and it has never been back except for a couple oil changes.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
