Sponsored by: Real Truck
Front End Noise
Old Oct 5, 2018 | 11:41 AM
xd2200's Avatar
xd2200
Front End Noise
Re: 2002 SD 5.4L 4x4
When coming to a stop a hear a "snap" - it happens under light braking but not heavy braking. It is a single snap not a series. Seems like coming from front possibly left side? My first thought was stabilizer links but I installed new Moog greaseable units 2000 miles ago. As far as I could determine everything underneath seems tight. Any thoughts?
Old Oct 5, 2018 | 12:25 PM
FractureCritical's Avatar
FractureCritical
I'd start with the slide pins on the caliper
Old Oct 7, 2018 | 02:42 PM
xd2200's Avatar
xd2200
I cleaned/greased slide pins on front calipers - still had snapping sound. I disconnected front sway bar links - still had snapping sound. I understand that slip joint at rear of main driveshaft could make a similar noise. Any other thoughts?
Old Oct 21, 2018 | 08:30 PM
xd2200's Avatar
xd2200
AND WE HAVE A WINNER!...... I finally checked the ball joints the proper way (i.e.,put jack stands on frame, let front end hang free & used a pry bar to move wheel up & down.) Sure enough left ball joint was bad, Replaced and no more noise!
Dixon1948
1997 - 2003 F150
Apr 18, 2019 08:17 PM
Tonyyayo
2004 - 2008 F150
Mar 24, 2009 10:43 PM
chesapeake_seadux
Jun 29, 2008 09:22 PM
1985IDIFORD
Jan 28, 2008 07:41 PM
boatcop1
May 31, 2006 01:23 PM
