92 E350 Cutaway Rv Evap Vent Valve
Hi, we have a 92 e350 cutaway rv with 7.5 steel rear fuel tank. Looking for a replacement evap vent valve F2UA-9B593-AA or equivalent or modification as cannot fuel tank due to excessive pressure. Thx in advance.
Side view 2 ports on the top
Fuel tank
Valve top 2 ports on the right
Fuel tank
If that's a definite part number here's one or more:
Double-check the application as the number you've provided might not be a part number. It does appear to be Ford's numbering scheme however.
HTH
HTH
Thx. That is the number on the valve and it appears to be a ford part. It has 2 ports and the one in your link is single, will this work or does it have to have 2? Also just wondering if it is going to lock properly in the steel tank. Thx kindly.
QUOTE=JWA;18236617]If that's a definite part number here's one or more:
HTH[/QUOTE]
HTH[/QUOTE]
Perhaps check RockAuto or a local Advance Auto, NAPA etc etc.
HTH
F4UZ-9B593-F (replaced F2UZ-9B593-A) .. Two Port Fuel Vapor Valve / Marked: F2UA-9B593-AA / Obsolete
1992/96: E150/350 5.8L (351W) & E350 7.5L (460).
No Ford dealer or obsolete parts vendor has any. Try NAPA or an indie auto parts store.
btw: The F2UA-9002-EE number on the fuel tank is also an ID number, it is not the part number!
p51bombay
12-08-2018 08:04 PM
p51bombay
12-07-2018 08:07 AM
Hunt89
12-10-2011 08:43 PM
RKN
10-09-2010 05:15 PM
