Death Wobble TSB Info Requested
#31
Just got my '17 F250 CCSB back from the dealership on Friday and promptly drove from Houston to OKC and back. My death wobble is gone! In my case, it was due to a bad track bar joint (TRE) at the axle. They did address the steering stabilizer TSB, and I now have serious steering bias, but that's a minor issue, since the DW is cured. After the new year I'll likely upgrade to a Fox ATS.
#32
I can confirm this - my '18 is in the shop now for this issue. Talked to the dealership yesterday, and called a couple others in the area. The steering linkage stabilizer HC3Z-3E651-D is on back order. Didn't know about or talk about other components in the TSB. We have a trip planned at Christmas time - 2500 miles, the return half pulling a 5er we're buying on the east coast - and need to be solid before then. Talked through options with the guys at the Ford house, and ultimately decided to fork over some cash to my local 4 Wheel Parts to buy an upgraded steering stabilizer, install to be done free of charge by the Ford guys. When I drop the parts off Monday I'll be asking about the other items mentioned in this thread and the camber adjustments also recommended. Here's hoping that gets me where I need go... I don't particularly look forward to DW with a 5er on the back end...
#33
Since a few days after taking delivery of my new '18 KR in July, I could feel this was hiding in my truck. It had JUST happened to me on my 2015 days before I traded it so I knew what it felt like. Sure enough, this past Saturday at 7800 miles it happened. I had already purchased Fox shocks and stabilizer in preparation for changing those but haven't had time to install them. So I thought what the heck, I'd call the local dealer and see about the TSB and get the ball rolling on the alignment portion of the bulletin. The local dealer here in Austin (Maxwell Ford) acted as if I had called seeking the keys to Ft Knox. Very dismissive, said they had never heard of it, wouldn't even look up the TSB to see if they had the parts in stock without setting an appointment and leaving the truck for two days.
For those having this done, can you post what they are doing to the alignment SPECIFICALLY (maybe post a copy of the repair order)? I think I am going to skip the dealer BS, order the alignment pieces and have it aligned myself, then install the Fox stuff and be done.
#34
I don't have the specific part number in front of me at the moment - but it's a 2-shock Pro Comp. Truck has 30k miles on it now, and first occurrence was at about 29.5...
#35
Just talked to the dealership again. He's telling me they actually received some of the replacement parts from Ford this weekend, which is good news for us folks. Also told me that there was a minor amount of play in the trac bar ball joint so they're replacing that and the bushing. Still installing my after market stabilizer... I decided to just do the upgrade - don't want to be messing with this while pulling the 5er cross country...
#36
My service adviser hooked me up with a Diesel tech and we went for a ride - wasn't able to do it on command (never can can you?) and refused to believe me that the TSB also included track ball joint and alignment....this is after he spent quite a bit of time questioning whether I actually needed to drive a 1 ton, and explaining how "They all do that".
The new stabilizer helped, but I wont be back. and of course, it wobbled on me yesterday....I might take it somewhere else...
#38
That is my set-up also. The 2 shock Pro Comp was installed by the dealer when it came off the rail car, along with the level kit and AMP boards...
#39
#40
Based on what I have read here the ROOT CAUSE is not enough caster in the alignment. After talking to two Ford dealers, I am not sure I am going to waste my time for days leaving my truck for them to try and recreate the issue, then having to wait even longer on backordered parts. The ability to increase caster is controlled by two bushings that sit on the top of the front spindles. The bushings are concentric with a numerical value in degrees that set the base caster. Below are pics of both of my bushings (secured by the castle nuts on top of the spindle and ball joint). While the other bushings named in the TSB may be out of stock with the dealers (because this thing that no one at the dealer level admits is happening is somehow depleting all the supplies of the parts), the bushings are available in the aftermarket (and are much cheaper than from Ford at retail). I have managed to get the factory alignment specs (below) for my '18 CC SWB 4WD diesel. I am going on the alignment rack this Thursday to get it measured so I can order the bushings. Can someone post the entire TSB that shows what total caster values Ford is recommending in this TSB repair?
Thanks,
Jim
Driver:
Passenger:
Thanks,
Jim
Driver:
Passenger:
#41
I have managed to get the factory alignment specs (below) for my '18 CC SWB 4WD diesel. What I need to verify by someone who has aligned one of these is, is there a way to estimate which value bushings I need so I can order them before I hit the alignment machine. Or am I going to have two trips on the alignment rack, one to measure the current caster and one to install after I get the bushings?
#42
Where did you get this page/data from? I have been hoping to see this data. As for caster that was set up under a repair instituting TSB 18-2668, I can offer the following from Aquamancw on this forum: CASTER (L/F +2.8, R/F +2.4) and TOE-IN (L/F +0.4, R/F +0.5). The caster values on his truck fall within the ranges on the document you obtained. However, I have heard more than one person say that caster should be set near the upper limit of the range. That would suggest caster be set at or above +4 degrees. One poster on this forum who has a friend that's a Ford engineer reported that his friend said, "In a perfect world you'd set the caster near 5 degrees, but that is probably unattainable. Realistically you'll get +3 degrees." Now I admit to paraphrasing some of that quote, but the facts are accurate. To be clear, I am still on the steep part of the learning curve with respect to alignment, but I believe that I am getting near a plateau on the curve with respect to Sustained Steering Wheel Oscillation as Ford calls it. Caster is an important element in preventing and/or correcting SSWO/DW; however, I'm not sure that it is the primary element.
#43
#44
#45
We really need folks posting up their alignment sheets after the TSB is performed so we can develop a pattern as to which specs are showing promise. Below is the actual TSB (thanks to Dave here for providing). Interesting they are calling out a build date for the steering stabilizer, so maybe a batch of those had some issues or were too weak. Nonetheless, even if the stabilizer solves the problem, its not gone for good if in fact its a suspension and steering geometry issue.
