Sucking sound.
I would buy a smoke machine and test the intake for leaks before anything else. Or take it to a shop that has a smoke machine and let them do it. I wouldn't just pull off the intake manifold without testing with smoke first.
Machanics Smoke Tester
Are you getting any DTC codes or check engine light ?
-Mike
-Mike
I believe they posted earlier on some issues and their location...Estonia!
https://www.ford-trucks.com/forums/1...vi-owners.html
Based on the other thread is this a dual-fuel system? Gasoline and Propane or CNG?
Welcome to FTE!
Welcome to FTE!
Welcome to FTE!
Welcome to FTE!
-Mike
-Mike
Hola Amigos. Today was a wonderful day. Good autumn weather with nice autumn sun. Since I didnt get any anwers I diceded to take intake off and take a look on the vacuum line behind it. To be honest it wasnt so hard job.I was in no hurry and did everything slowly.
Vacuum line turned out to be fine, at least I didn't find anything broken or cracked, but there were almost no gasket between EGR and Intake, so I think that is the place where air were sucked.
Tomorrow I want to measure cylinder pressure before changing spark plugs. Btw , take a look on the pic, I think EGR never has been changed. Im not gonna touch it as well, let it work until its dead.
