New work truck with 6.7 questions - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 10-08-2018, 07:59 AM
bcg
bcg is offline
bcg is starting off with a positive reputation.
Originally Posted by mattt181 View Post
Thanks everyone for the info. I have to say I am shocked that Ford got the 6.7 that right and that it doesn't need to be Bullet Proof'd, or studded, or re-programmed. I hear little issues to watch for, but nothing like I had to learn on my old 6.0. Is the factory programming decent on the 6.7? After Ford dealerships kept flashing my 6.0, the truck turned into a turd and I paid to have my FICM repaired and re-flashed to bring it back to where it was power wise when it was new.
Kper05.....can I ask why you said that you want a DEF truck over a non DEF truck?
Am I reading y'all correctly that Cab and Chassis models had a lower output (guessing via the tune) from the factory? Since I am only looking at F450 & F550 that pretty much means I will be corralled into a lower output engine. My old truck was a 13' stake bed body so the ~200" wheelbase truck is what I start with. Bummer to hear that Ford de-tunes the F450 F550 C&C :-\
This is correct in the Cab & Chassis but, there is a pickup version of the F450 that has the full power motor, I have one. You can still put a flatbed on it, it's just a little more work since the bed rails are a little different. A 13' bed would be a little long, 10' is probably the max I would go on mine, it will be getting a flatbed soon, most likely 8 - 9 feet. The power reduction in the C&C is more than just de-tuning, the turbo is smaller and there are some other mechanical differences in the motor, it's done to improve longevity.
Also, it is possible to have a 6.7 that doesn't need DEF, it just requires putting it on a weight loss program and changing the programming. My truck doesn't require DEF.
Others have already said it but, if you can go a 2015 or later. I limited my search to trucks 2103+, the 2015+ were just a bit out of my budget.
Old 10-12-2018, 10:56 PM
maxum96
maxum96 is offline
maxum96 is starting off with a positive reputation.
Ford didn't design or build the 6.0 and 6.4 engines. International did and sold them to Ford. The 6.7 is Ford designed and built.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
