Ford Truck Procrastinators Club
#31
#32
on
Well I'm kinda thinking. I belong on here as well......my intention was once I got done my 49 f-4 I was going to get started on my 1949 8n........ it is disassembled and needs a head gasket...and I figured how's the time for a full restoration on it....my plan was to have that done by October......so now do to procrastination I will start it in the spring.....
#33
I might have to resign from the Ford Truck Procrastinators Club.... Tonight I put on that fuel pump that has been sitting on my work bench since early June!
I bought it because my 55 would cut out at higher RPMs if I wound it out in 2nd or 3rd or floored it in 4th. Here's what I did to try to fix it at the end of May: rebuilt the carb, replaced the points (with an NOS set), condenser (with an NOS one), plugs, plug wires, distributor cap. This tune-up didn't help. I replaced the rubber fuel line thinking it was old and soft and collapsing. My mechanic buddy thought maybe the fuel pump could not pump enough gas when it needs it. The truck ran fine around town but I was afraid to drive it to Ford Carlisle and didn't. Since it ran well I didn't get around to doing it. Until late this afternoon.
And after a test drive.... no change! So what now? I guess I should've procrastinated a bit longer.....
#35
I might fit in here too! lots of talk and no truck action. I developed a plan today to sell all my hobby stuff and convert a building into a work shop. Well I set that thought aside for another day. Was good to list all the junk I have collected! I should have been out working on my current orange project. But instead its more fun to get on here and see folks actually doing something!
Regards,
Chris
Regards,
Chris
#36
Another chapter closed on my Ford Truck Procrastinators Club story.
When I fixed up and painted my 54 the first time in 1999 I replaced the original hood with a better used one. When I bought rubberI bought the piece that hangs down from the underside of the hood towards the radiator. The used hood did not have the C-channel on it to attach the rubber with. And so I let it go.... Two years ago I got a length of C-channel made at a local sheet metal shop. It and the rubber piece laid on my workbench for those two years. This fall I started to do something about it.
I wasn't sure how to attach the C-channel to the hood flange. Another problem is that the hood flange is curved like the hood and the C-channel is straight. I thought of welding it on or trying panel adhesive. Someone here suggested I pop rivet it on. So the last several nights I have been working on it... I drilled holes in both the C-channel and the flange until the straight of the Channel and the curve of the hood flange got too far apart to get a hole and a rivet in both. I found out some of my rivets didn't hold. They were not long enough. I went to the hardware store to get longer rivets but they didn't have any longer ones. So I bought short bolts. SO I have a combination of 3 little bolts and two rivets holding the C-channel in place.
So after almost 20 years I have the hood to radiator rubber in place! Not bad. Next I have to work on making my stock 54 fan shroud fit the good used V-8 radiator the seller says he had in his 56. The radiator is like a half inch wider on each side.
Pics to follow.
Pics to follow.
#37
#39
Another procrastinated job finished!
I bought a good used radiator on eBay in 2017 for my 54. It was a good buy, $90 plus only $20 shipping. It came from a 56. I had it pressure checked at my local radiator shop. It was good.
And then it say in my garage for a long time. I didn't feel like going through all the trouble of draining the old one, and putting in the new one.
So after a year I took it to my local garage. The one brother called me and said my fan shroud didn't fit on the new radiator. I said it should, it is from
a 56. He said the shroud is a little too narrow. He recommended putting on narrow pieces of sheet metal to widen it. I got two pieces like this.
Last week when I was looking at my clear fuel filter while the truck was running the fan just ever so slightly touched my finger! No blood but it scared the heck out of me! So scared that it gave me motivation to get the shroud on.
Today, the wife was away and I thought now is the time. I washed and dried the shroud then painted it, drained some antifreeze out, disconnected the radiator pipe and fan. After I got the shroud in place I could see that the shroud was just a bit too narrow. No extensions were needed I thought. But I needed help so I called my buddy Bill. Bill and I got it on with some pushing and pulling. We only had to elongate one hole by drilling.
So, it took me a year and one half to get the radiator in and another year and a half to get the shroud in place.
#40
#41
My name is still pretty much darn near the very top of this list. Maybe I should try to do something on the F6 soon.
#42
I've had a pair of new rear main seals soaking in a container of motor oil for two months now. One of these days the soaking process will be complete, and then I'll have to drop the oil pan and tackle this job. We have had record breaking heat here this summer, so my motivation level is pretty darn low.
Soon it will be too cold out there. Maybe the oil drip isn't that bad. I have plenty of cardboard to chuck under the truck. Someday those seals will be done soaking................
#44
Well my door rubber is probably about 4 years old. Maybe I need to get that installed sometime soon.
I bought the window channels in 2017. Stopping the windows from rattling might be a good thing. Oh yeah, I have a new passenger side window, I need to install that before long. The window is cracked and might get worse someday. I've had the new window for a few years as well.
#45
