Tires from Craigslist--new but 10 yrs old ??
You won't get a reputable tire shop to mount or balance them for you no matter how much tread there is or how nice they look.
Just my .02
Prepared to get shot down in flames here but, when I bought my current truck (2000 F350 dually) it only had 19k KM's on the clock, this was only 4 years ago & it still had all 7 original tires. The truck was driven back from Spain to the UK (some 1500 miles) & I then put another 60k KM's on 4 of those same tires, 2 were changed due to cracks, another 4 were changed as they were getting low on tread, I still have the original spare! I'd be happy to run those tires but the price is far to high. You can buy "brand new" tires that are up to 3 years old.
Last month we had a flat on the wife's 01 pickup, pulled the 17 year old spare out from under the truck and finished the trip, first time it had been on the ground.
Bought a replacement tire for the alloy rim to go back on the truck and stuck the spare back under the bed.
Been there. Done that. More than once. (Slow learner). Have the shredded tire carcasses and wrecked fender to prove it.
"New" tires. Full depth and flawless tread. Even had the little "knobbies", thread forming die dross, and color coded stripes all still in tact. Stored indoors, in a dark windowless warehouse, away from any sunlight, for 10+ years. Half that time by me, not some shady tire dealer. The other half of that time by a trusted acquaintance, whose storage method I witnessed. Factory OEM take offs, set aside for bigger tires by the original owner soon after delivery.
Neither the robustness of the "regroovable" casing, nor the formidable F rated load range, nor the sanctity of the new tire smell that still lingered in these well preserved rubber relics.... stopped them from blowing up on the highway.
Not worth it for $500. Not worth it for free.
Your tread doesn't look quite like Marathon, albeit my Marathons on hand that I have to compare are "expired" rollers, used for no other purpose than holding the trailer up off the ground, so the tread design may have changed.
On the other hand, your tread doesn't look quite like Goodyear's new Endurance trailer tire either, which was recently introduced around three years ago, and which replaced the long running Marathon.
Yet you said you bought this tire 3 years ago, so both models of tire are a possibility, even while neither tire matches the tread pattern for either model... at least the tread patterns I've seen.
If I had to guess, I would say you had a Marathon, which are definitely no longer recommended among the RV community. But if you had an Endurance, that would worry me a bit, because I was hoping that Goodyear solved all of their ST tire problems with their Endurance model.
So please answer the mystery!
#29
Shovelhead... please tell us the model of Goodyear trailer tire that blew out above... is this the Goodyear Marathon? or the Goodyear Endurance? or Goodyear something else?
#30
