Hello All,
I'm looking at some used wheels and tires. The wheels are 16x8 with 4.5" back spacing and 5 x 5.5. My question is,, will I have problems with this much back space on a 79 f150 4x4? I know ideally I should be somewhere between 3.5" & 4" but that would be with a 15" wheel. So will a 16" wheel help clear the tie rod end or will the extra back space negate the extra diameter? Will the 4.5" b/s make the lockout hubs stick outside the wheel? I would like to move up to a 16" because of more tire options. Really I would like 16x10 but they are hard to find used.
I have a set of 15” rims on mine and they have exactly that much back space. No issues what so ever.... I should add i have a set of super duty rims that are 18” with 6.5” of backspace. With the 2” adapters(bringing the backspace to 4.5”) they also fit perfect. Your set
Hello All,
Thanks to all, Chris
1" added diameter is only adding 1/2" space from center. Another thing you have to consider is what tire size you'll be running? What kind of wheels are you looking for? I know some places like Jegs, will have their steel wheels made to any offset you want if you call them and it's about $20 extra per wheel. Just had a buddy do this on some steel 6 lug 15x8s for his Wagoneer
I think 4.5 backspace 16's is what I have now on a 79 F150 4wd. When I ordered them at tire store I gave them specific backspace measurements. The jackass behind the counter whipped out his only brain (keypad) and ordered 5.5" backspace because that's what his computer told him to order. I think he was looking at 2wd specs. When I arrived to pick up the wheels and tires they had already mounted the tires and I told him they were wrong but I'd try it as long as they were liable. Sure enough, the rims contacted tie rod ends. I ruined a pair wheels. Tire store made it right.
Wont the extra back spacing place the tire closer inboard to the leaf springs or radius arms?OR am I moving the "B/S" the wrong direction? I do not want tire rub. The tire/wheel combo is a 37" tire on a 16x8 wheel with 4.5" back space.
With this back space, will the lock out hubs stick out past the wheel or tire? I do not want the lock out to be possibly damaged while off roading. The tires have 17/32 tread and the wheels appear to be in good shape. The seller bought the vehical that had these on it but does not want a 37" tire with steel wheel. He wants to go 35 and aluminum. He is selling for about 650.
Reason: forgot something
with 37s, they’re likely 13.50 wide, I would expect them to rub before you hit full lock with 4.5” backspacing.
The only place you might have an issue is fitting 37” tires. I have a 3.5” lift. I dont know that 37s fit wittout rub.... if backspace from rim was an issue it would hit tie rod. But your not adding any more than 4.5”. ...650 is a solid deal IMO.
