Very rough idle/slight backfiring
Ok so I have a 94 f150 with 300 6, m5r2 transmission. Burned up 1st motor and bought a used one, dropped in the new motor and this started happening. The idle is so rough and choppy it dies sometimes. Rpms raise, drop, backfires if I hit the gas. I've replaced dizzy, plugs & wires, copper core motorcraft plugs gapped to specs, cleaned IAC new MAP new PCV, timing was set to 10° btdc with PILL out (or as close to 10° as I could get with it running like this) timing may be slightly off causing backfire but main concern is rough idle. Checked firing order and re-checked, everything is correct. I was thinking leaking vacuum hose but cant seem to find one. Unplug a vacuum line and symptoms do not get worse or better, does this mean it could be a vacuum line? If not, what else should I look into? Thanks.
No check engine but it may not have ran long enough for it to come on. The o2 sensor is disconnected and the light is off which makes me think the truck hasn't run long enough to pick up any codes. I've disconnected the sensor and the truck dies, replaced the sensor and no change to the idle issue.
on
No the engine hasn't gotten to operating temperatures and fuel psi is at 50 - 60 fluctuating slightly. The engine was pulled out of a 92 - 96 f150, somewhere in there, and no I stripped it to the block, did a seal kit and dropped it into my truck with all wiring/accessories/vacuum lines from original engine. Havent gotten around to compression test yet, I was rained out. Maybe tomorrow.
I'm really stressing the valves. I am pretty sure I seated all the retainer clips properly when I changed the valve seals but maybe one wasn't seated? It sounds like it's running smooth and no loud clattering for the first maybe 5 seconds but after that the fluctuating idle starts happening, so I wouldn't think it's a dropped valve but I just dont know where else to look.
