dana 44 bearing caps
Pulled a 44 apart to replace the inner seals and noticed that the caps were installed wrong left to right. This was done by a previous owner 20 plus years ago. Its never given me any problems save for the leak. Should I put them back on the way they came out or the way they should be?
Thanks
Thanks
You should try to get them on right but at the end of the day, it wouldn't make any difference.
Why new bearings and races now ? Any time you change bearings and races anything can happen. I would check back lash and check for any horizontal movement in the carrier. I would also recheck the gear pattern with a compound.
$Simpleman76
07-18-2007 01:30 AM
Scoarch
10-01-2005 11:17 PM
