No accelerator until GPR clicks off - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 10-17-2018, 08:01 PM
merc123
merc123 is offline
merc123 is starting off with a positive reputation.
Figured out it's a legitimate wire. It's for the glow plug relay monitor circuit.
https://www.ford-trucks.com/forums/1...ay-wiring.html
Old 10-17-2018, 08:04 PM
merc123
merc123 is offline
Originally Posted by DieselDenny View Post
Most definitely!!! At the very least after your work, surgically clean and treat all grounds (major) and your supply lines.
I equate what your doing to surgery in terms of fixing and solving a problem.
Hat's off
BTW, Cleaning your hard points on these rigs are something to be done at least bi-annual. Otherwise..................
Denny
Thanks Denny. I put a new crossover cable on today because the old one was wiggling pretty good. Also noticed my alternator is putting out 14 volts and climbing to 16 the longer the truck idles. I think it may be time to replace the wiring and grounds on it with all new also since they have 178k miles on them.
Old 10-17-2018, 10:05 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
My l99 and 02 have a BLUE big-ringed terminal wite thats secured on same lug as the yel/brn wires
Old 10-20-2018, 06:24 PM
merc123
merc123 is offline
I believe, fingers crossed, itís fixed.
TLDR: new ground wire terminals and charged battery.
We cut off the ends of the ground wires and put new bolted terminals on. We also put both batteries on charge. They were down to 50% on the chargerís meter but only 12.5 volts. Load test showed fine and multimeter was showing 13.5 volts,BUT, when running the multimeter is showing 18 volts! Charged battery to 77% and 95% and shows 13.1 on battery charger. The battery meter in the truck does NOT pull down now like it did and had full pedal on 2 restarts even when glow plugs are activated.
Old 10-21-2018, 11:23 AM
PrescottIce's Avatar
PrescottIce
PrescottIce is offline
PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.PrescottIce has a good reputation on FTE.
Here's to hoping!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
