Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
October 2018 Chat
Old 10-30-2018, 09:42 PM
hturner12's Avatar
hturner12
hturner12 is offline
I agree 100% and strongly believe in K.I.S (S) depending on if you are talking to someone or yourself. Other folks get **** when you use the 2nd S(tupid) on them. Where I get irrated is based on your experience the solution is X they never try it and keep asking for help. I have even ask someone else to look at something, line something up start a bolt cause whatever it was does not like me. I think my tractor is jealous of the sawmill it has not meet.
The only time I got **** about people asking my opinion was in the AF as a flightline supervisor on tire inspections. If someone was doing a tire inspection if a tire needed to be changed, I could give them the answer without ever see the tire. The tech manual was very specific on what was good and what required a change so if the could not read then they did a tire change. Sometimes I had to certify the aircraft back to flight status part of that was an inprogress inspection on certain steps. I was very clear for them to stop and call me, when they did not and called me to sign off the completed job. It was no problem once you pull the tire back off to the point I need to inspect it.
  #152
Old 10-30-2018, 09:45 PM
hturner12's Avatar
hturner12
Originally Posted by ChiefM
The whole loader assembly, the arms. the lines and bucket.
I thoughtI was going to have to drop mine for the split. Luckly it was just a few bolts on the tie arms. If I ever have to do a clutch then the loader has to come off they use the bellhousing for support
  #153
Old 10-31-2018, 04:58 AM
ChiefM's Avatar
ChiefM
ChiefM is offline
Putting the arms on is not that bad. The bottom pins sit in a saddle and you just lineup and install the upper pins. The hard lines on the arms are already installed so the hardest part is running the rubber lines from the right side arm to the hydraulic manifold. That's not that bad either now that I know how it runs and mounts. I can already tell a difference in gas savings by not having to drive so far. The guy that works on mowers and is going to work at the Rome store also works on 4wheelers. I am going to get him to fix the Kawasaki 750 for me after Christmas. I changed my linkedin profile to show my new job. It will show all my connections my new title and both my old bosses at Yancey are on there.
Downtown has a big to do for trick or treat so we decided to take little man out for his first time!!
  #154
Old 10-31-2018, 05:14 AM
hturner12's Avatar
hturner12
A new easy job, our VA money is in the bank (at least mine is ) good week.
  #155
Old 10-31-2018, 08:43 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
Received 1,520 Likes on 1,418 Posts
Stephen hope you did go to the trick or treat and take off your mask and scare everyone. LOL
Hugh, like everyone I take exemption when some say "I did" but it is most of the time in how they say it! LOL
  #156
Old 11-01-2018, 04:18 AM
ChiefM's Avatar
ChiefM
ChiefM is offline
Little man was all dressed up and ready to go trick or treating and then he got sick, all over himself and the car. My wife was heartbroken.
I am still loving the job. The service manager in Cartersville is very impressed with my work and wished I had applied for a tech job with him.
cornking
06-06-2012 07:49 PM
SideWinder4.9l
07-30-2011 07:25 PM
whf
1999 to 2016 Super Duty
07-27-2010 12:11 PM
texasmaker
2004 - 2008 F150
02-06-2005 03:50 PM
Munkey
09-14-2003 02:58 AM
Quick Reply: October 2018 Chat
