Inside Door Handle Rubber
E7TZ-1522600-A, RH, Black - Still Available from Ford - MSRP $13.33
E7TZ-1522601A, LH, Black, Still Available from Ford - MSRP $15.28
N605890-S301, Attaching Bolt, Still Available from Ford - MSRP $3.00
Edit - Wait did you mean the material around the door handle? That is attached to the door panel...
Well... thanks to this thread, I now can't stop noticing that my drivers door is missing half of the door handle pass-through. So I stopped by the PullaPart this morning and found a drivers door panel that someone had already removed, and I popped the pass-through off... only slightly damaging it. I think I will be able to remove mine, and glue this one in place... but we'll find out! If so, then I'll grab some more from the PullaPart, the door panels are often trashed but the pass-through is usually fine. Pictures to come.
Pebcak
18
09-29-2016 01:03 PM
69 F100 Cali
11-20-2011 08:42 PM
