Field Service Action --18N03
#61
Not to change the topic on this thread but it might be worth compiling a list of the bigger 'across the board' issues that people have experienced.
1. Electrical connectors becoming corroded.
2. Door latches freezing
3. Tail gate opening on its own.
4. Fuel pump issues
5. Offset cabs
6. Warping dashboards
7. Leaking batteries
8. Corroded wheels on dually's
9. Ford Pass not working
10. Sync 3 upgrade and not remembering the last radio station or audio input setting
What am I missing?
4. Fuel pump issues
5. Offset cabs
What am I missing?
#62
#63
#65
Received 6,671 Likes
on
4. Fuel pump issues
5. Offset cabs
What am I missing?
4. Fuel pump issues
5. Offset cabs
What am I missing?
12. Death Wobble
I've experienced the leaking battery myself. The others, not really. My tailgate may have dropped once on it's own. I greased up all the connectors under the truck and have had zero problems since then. I think a lot of these issues are isolated. We hear about them on the forums because people come here with problems. There are a LOT of owners that probably have no issues. Some of these problems may be regional too. It's so dry here that any connector with water in it will stay wet for a very short period of time. Only Ford can really say how big these issues are across the entire population of Superduty trucks.
#66
#67
Hey Guys,
I started the poll on reporting the most popular issues.
Here is the link...you can choose multiple issues if your truck is impacted by more than one of these.
Thanks.
https://www.ford-trucks.com/forums/1...uper-duty.html
Thanks.
#68
So, I just picked my truck up this morning after having the work done. My "local" dealer (Thomasson Ford) is likely the smallest Ford Dealer in the continental US. This was my first experience with them.
I immediately noticed the black _whatever_ showing in the gap between the door handle insert and the door itself. See pics below. Other than that I don't notice anything externally on the truck. You can see a little bit of black silicone just below one of the handles. I was able to wipe if off.
That aside, I really don't understand why technicians don't clean the evidence of their work off the vehicles. I have had the truck at a dealer twice now; once for the fuel tank TSB and now for this. Both times the truck was delivered with dirty hand prints on it. This time also on the interior door panels.
I know its a truck but the truck was freshly washed and detailed when I dropped it off. The truck is kept clean and it should have been obvious to the tech. The truck is more expensive than almost any Lincoln you can buy so why does it not get the same level of attention? The dealer that did the fuel tank TSB isn't a mega dealer but they were large enough to have a separate "truck shop". The driver's door had hand prints on it that I could see from 50 feet away.
It will be interesting to see if I have any more trouble with the door latches. Its raining as I write this.
#69
Wouldn't be bad if it actually fit right...looks like crap IMO. Maybe even on Magnetic. At least it's consistently on the back side of each handle. I think I'd rather clean their mess myself than to get the red shop towel wipe down & buff.
Thanks for posting your experience! How does the rest look? Did you also get the new latch / actuator assemblies?
#70
It was raining by the time I got home and hasn't stopped yet and is forecast to continue until sometime Saturday morning. Hopefully, I'll get a chance to inspect the work and see what else I can find.
The CSR would only say that they have to take all 4 doors all the way apart and install a kit. As soon as I asked what constituted the "kit" he turned and walked away saying "if you have any trouble with it let me know". Clearly he didn't want to discuss the job any further.
I owned a couple of Aamco Transmission Centers for a year years in the early 2000s. I always made sure my customer's vehicles were cleaned before we returned them. Dirty vehicles leave a very bad impression on customers. For our better customers we would have car's washed at the car wash down the block.
#71
Had my latches replaced yesterday. Was told 1/2 day job. Rented car for that day. Got a call later in the after and was told is was a 2 day job even though parts were confirmed in stock with my name on them at time of drop off. Received truck after nearly 72 hours and $125 in car rental charges.
This morning it is 26 degrees outside and latches work...but they have not been exposed to rain or a truck wash yet...time will tell.
Lots of yellow-ish grease inside the door latch mechanism on all 4 doors. It's easy to see when you hold the door handle in the open/pulled out position.
Truck does smell kinda newish again though. So that's an added bonus.
#72
Just pulled the door panel to replace the factory speakers only to find the back side of the outer door skin soaked. It rained all last night and there is literally water running down the door skin. Not to mention I have duct tape over a couple of the holes in the inner door skin. Pretty sure the factory isn't putting duct tape on the door skins of these new truck.
#73
