1997 F 350 . 5,8 gas Smog Pump Replacement
Smog pump is making a lot of noise . Afraid it will lock up and want too replace
bracket with pulley or rebuilt ?
Have seen a few posts indicating Don't get ---- --- --- bit off ,
. I have the 5.8 gas with A/C
I live in Fla smog pump not required .
Not removed .yet
Napa & Discount have rebuilt for $ 105 bucks . They indicated there are two but only one is available and I need too make sure of part number
ALSO
If I choose too go bracket with pulley , is it an exact replacement, have too cover manifold pipe opening ?
REMOVAL of pump
Not eager too take apart items I don't need . How many bolts and what is required too remove pump . Looks like one bolt is holding pump from opposite side ?? if so a pain or did I over look another bolt . HOW Many bolts 2 ? Do I have too remove tensioner , and other items too remove pump
thanks
Not removed .yet
ALSO
REMOVAL of pump
thanks
zak8tac
07-06-2012 12:30 PM
