Sloppy steering
Old Sep 26, 2018 | 12:59 AM
StrokinIT2001's Avatar
StrokinIT2001
Sloppy steering
My steering wheel is very sloppy how can I fix it?
Old Sep 26, 2018 | 08:00 AM
RigCity's Avatar
RigCity
Yea let me get the list for you lol
steeeing gear box
pitman arm (reusable mine had damaged splines)
hydro boost pump
ball joints
tie rods
drag links
steering colum (mine had 3 problems broken bearings, clock spring, and had to disconnect the shifter cable to manually change gears at the cabl so I replaced the entire unit) there are bearings inside there that the steering shaft rides on if they go out the wheel will move in several directions like it is loose from inside the cab)
Wish I replaced them ALL at once I will next time every time I changed those I would notice a large improvement. The truck has gone from 45 degrees of play to driving like a car
2 front shocks and track bar is all that’s left for me on the front end. This two are not as closely linked to a loose steering as the priors.
Old Sep 26, 2018 | 01:39 PM
viperman86's Avatar
viperman86
mine is shot too, probably the steering box
all suspension components should be checked, pitman arm, tie rod ends, ball joints
Old Sep 26, 2018 | 11:01 PM
'88 E-350's Avatar
'88 E-350
Could be lots of things. Have someone in the truck rock the wheel back & forth while you look at the steering parts and see if you can spot the source of the slop.
Old Sep 27, 2018 | 09:23 PM
StrokinIT2001
I mean it is hard to keep it straight in the lanes. It’s tight up down right and left just has 3-4 inches of room before it actually turns the tires.. I adjusted the gear box screw and it bottomed out but didn’t help.. new gear box in order???
Old Sep 27, 2018 | 11:00 PM
Colorado350's Avatar
Colorado350
If it’s bottomed out then probably. I’d send it to West Texas Off-road and have them rebuild it. If you’re running larger tires, might as well have them port it too. Then you’ll have the option of hydro assist if you want it.
Old Sep 28, 2018 | 04:42 PM
slpcth's Avatar
slpcth
Along with the other advise don't disregard the Track Bar. My truck was the same way. You would swear I was drunk. Turned out to be shot track bar bushings. Put a new "Zone" adjustable bar and steers like a dream.
Paul
Old Sep 29, 2018 | 08:06 AM
Tugly's Avatar
Tugly
Bottomed out screw? Yeah... if the steering box wasn't shot before - it is now.
neader
Dec 18, 2011 09:23 AM
lari250
Nov 28, 2010 06:05 AM
The Conqueror
Nov 4, 2007 07:37 PM
use4low
Dec 18, 2005 01:30 PM
bigorangenation
Jul 16, 2004 01:21 PM
