1963 Econoline Left turn signal problems
Old 09-25-2018, 02:27 PM
stm76's Avatar
stm76
stm76 is offline
Lightbulb 1963 Econoline Left turn signal problems
I'm new here. I just bought a 1963 Ford Econoline van. (I had a 61 in high school so this is my midlife crisis purchase to take me back to the good old days). My right turn signal works great, it blinks and cancels itself just fine. The left turn will light up, but not blink and also does NOT cancel itself after a left turn. Any ideas what I should be checking. Very strange to me why one side would work and the other won't.
Old 09-25-2018, 07:08 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
Does both the left front and left rear light up (no burned out bulbs)?
Are the lamps correct? LED or lower wattage lamps will not produce enough current to make the blinker blink.
The non-cancel issue is typically a broken plastic part under the steering wheel. You will need to replace the turn signal switch.
Old 09-25-2018, 08:53 PM
stm76's Avatar
stm76
stm76 is offline
EmilBarnabas, you are a genius. Such a simple fix. The rear left light was NOT turning on at all with the blinker. The light seems to not have been making contact correctly. I pulled it out, cleaned the contacts and put it back in and the left blinker is working again.
The bulb is very loose in the housing, like it isn't the correct size or something. Anyone know which bulb is supposed to go in there? Anyway, it is working for now. I'll have to get one of the replacement plastic parts for the steering wheel to get it to cancel correctly, but I can live without that for a bit.
Thank you
Old 09-26-2018, 12:15 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Thank you
Industry number: 1157 double filament bulb (clear) used with parking and tail lamps for all 12V Ford vehicles from 1956 thru at least 1979. There is also a 1157NA amber bulb.
This bulb has two offset pins, so it can only be installed in the sockets one way.
The plastic canceling cam that is part of the T/S switch is available from auto parts stores, but it can be a real b!tch to install.
Ford never sold it by itself, it was only furnished with the T/S switch.
Old 09-26-2018, 07:04 PM
EmilBarnabas
Loose side to side like the wrong diameter base, or loose like the spring holding it in place is wearing out? Is the bulb the 1157 that Bill mentioned?
If the spring has lost it's springiness, which can happen if the socket gets corroded, you can cut the connector off the cable and push/pull the wire out from the bulb side and replace the little spring that sits behind the bulb and wraps around the wire. I think I used a spring from a ball-point pen last time.
Then you have to splice the wire back to the connector.
gfburke
04-09-2014 05:01 PM
12valveEx
07-07-2013 10:33 PM
pressureelite
1997 - 2003 F150
04-25-2010 04:18 PM
dogobat
04-22-2007 01:16 AM
Storm
1999 to 2016 Super Duty
02-04-2007 09:28 PM
Quick Reply: 1963 Econoline Left turn signal problems
