1972 f250 brake problem - Ford Truck Enthusiasts Forums
Old 09-24-2018, 06:35 PM
Brian9568
Brian9568 is offline
Brian9568 is starting off with a positive reputation.
​This is my second post of this. I had it in the 73-79 forum on accident and i didnt know how to move it over so i am reposting I have a 1972 f250 with a 390 and disk brakes in the front. I'm having issues with the front brakes it leaking from the nipple thing on the distribution block or proportioning valve not sure exactly what it is maybe someone can help me figure it out or where I can get a new one or a rebuild kit of some sort ive tried looking everywhere only place i have found it was ebay and its gone now lol heres a pic of it hopefully it helps
Old 09-24-2018, 08:08 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C8TZ-2B161-A .. Metering Valve-Use with dual piston caliper disc brakes / Obsolete
1968/79 F250 2WD & F350 ~ No Ford dealer or obsolete parts vendor has any.
Note: Some 1973/79 F250 2WD's have single piston caliper disc brakes, do not use this valve.
Old 09-24-2018, 08:31 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to beholdford390gashog is a splendid one to behold
It's not needed replace it with a brake line tee.
Old 09-27-2018, 09:10 PM
Brian9568
thought about doing that but didn't know how important it was. Figured it was there for a reason must have some sort of use besides being a splitter
Old 09-28-2018, 05:57 AM
ultraranger's Avatar
ultraranger
ultraranger is offline
ultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud ofultraranger has much to be proud of
The metering (hold-off) valve does have a purpose. It momentary blocks fluid pressure from going to the front discs, in order to give the fluid pressure acting on the rear drums time to overcome the tension of the brake shoe retracting springs and start moving the rear brake shoes towards the inner friction surfaces of the drums.
The momentary delay by the metering valve is designed to give the rear brakes a head start so that all four brakes apply at about the same time. Discs, without a hold-off, would apply immediately when the brake pedal is stepped on. Drums don't respond immediately because they have mechanical components to overcome before the shoes begin to make contact with the drums.
Old 09-30-2018, 10:28 PM
Lrrr-RulerOfOmicronP's Avatar
Lrrr-RulerOfOmicronP is online now
Lrrr-RulerOfOmicronP is starting off with a positive reputation.
Here is some good reading. Hope it helps.
http://www.fordification.com/tech/propvalve101.htm
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
