89 F150 transmission fluid low / no leaks - Ford Truck Enthusiasts Forums
Old 09-24-2018, 04:02 PM
johnnyfoodstamp
johnnyfoodstamp is offline
johnnyfoodstamp is starting off with a positive reputation.
1989 F150 Lariat XLT 5.0 2x4 here. I've had to top off the transmission fluid a few times so I took it to the shop assuming I had a leak. No leak could be found. Not at the pan, or behind the inspection plate, or any of the seals. They said it was good. So where is it going???
Old 09-24-2018, 04:32 PM
Roger T. Pipe's Avatar
Roger T. Pipe
Roger T. Pipe is offline
Roger T. Pipe is starting off with a positive reputation.
Change your modulator...about 25 bucks at any auto parts store.
Old 09-25-2018, 10:40 AM
johnnyfoodstamp
This is the AOD not the C6 so there is no vacuum modulator.
Old 09-25-2018, 10:43 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Your truck has a transmission cooler mounted in the bottom tank of the radiator. Sometimes the cooler leaks into the cooling system. Check the coolant for signs of contamination.
Old 09-25-2018, 10:50 AM
johnnyfoodstamp
I flushed the coolant maybe 2 years ago and it was fine. And the shop said they drained a little coolant and it was fine. But I have noticed the temperature gauge will spike every so slightly every now and again and then go back to normal. I wonder if this could be a sign? I'm also going to drain the coolant myself this weekend when I do an oil change. The only thing is I swear I've seen red fluid under the truck but they couldn't find a leak after 2 days of looking at it. This is very odd.
Old 09-25-2018, 10:51 AM
johnnyfoodstamp
I've got cardboard under the truck for now and I'm going to meticulously clean everything and get to the bottom of this leak.
Old 09-25-2018, 01:56 PM
rla2005's Avatar
rla2005
Good plan.
Old 10-10-2018, 06:08 PM
johnnyfoodstamp
So I've had cardboard under it and no leaks. But I'm still using transmission fluid. And the radiator coolant is bright green and looks fine. I'm stumped....
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
