Truck wandering after ball joint replacement and alignment
Morning folks
2002 F350 7.3L 135k miles
Replaced ball joints on both sides of the truck and had the wheels aligned after. Also had replaced a worn out drag link (all three pieces)
Now the truck wanders/overcorrects at highway speeds. No play in steering box. The guy that put them in used ACDelco parts. Do you think this could be an installation issue? I've only put 200 or so miles on, is this something that might go away with time?
I've seen piles of threads with this issue but no one ever updates. Anyone experience something like this?
Same issue with 03
Morning folks
I’ve been having the same issue with my 2003 since replacing the entire front end. Any help would be appreciated.
Let the ball joints break in, and change the track bar if you haven't already. Its relatively cheap compared to the rest of the front end. Then make sure your steering box is tightened up. Good luck! Please let us know if this helps.
00Dave
48
06-22-2011 12:22 PM
robinsonpowerstroke
16
01-03-2011 10:27 AM
