M5OD won't go into any gear.
I took my 1995 F150 down the road to the gas station today and everything seemed fine. But when I pulled back into the driveway (my driveway is downhill, so I had the truck in gear with clutch in, just coasting to where I park. I went to put it in first to park the truck and it came out of gear and won't go back in. Also the shifter will move so that it looks like it will go into 5th and reverse, but it's not. It won't go into the first, second, third or fourth positions. Clutch is working fine. The truck is in neutral no matter where the shifter is, and the shifter feels really loose. I pulled the shifter out and can't see anything obviously wrong.
Any ideas? Is my transmission cooked or are the forks binding on something? I've got no idea.
That sounds like a shift fork has slipped over the collar it rides in and is stuck past the lip. This is usually a result of worn shift forks. Some people put their hand on the shift lever while driving and that can force the fork to ride against the collar lip wearing the fork out prematurely. Also when you are coasting in to a light or driveway, if you push the clutch in you are causing unnecessary wear on your throw out bearing. Same thing at a stop light. Go to neutral after almost stopped and let the clutch out then shift into gear when the light turns. Since you checked the lever area, I would pull the cover and see what your shift forks are doing. You will see the place where the forks ride until engaged. Before you do, you can also apply some pressure to the lever and force the fork back over the lip and into the slot sometimes if you want to try that. Then replace forks. This has been my experience with mine. Sandy
I did pull the boot up off camera and didn't see anything. Nonetheless I will make a video and post it up of the shifter itself removed. I have already replaced those shifter bushings if that is what you are referring to.
I was thinking of your issue and remembered I have a cover from my 95 that I dropped and cracked. There is a spring loaded lever on the bottom of the cover where your shifter goes and it moves a lot as you can see from the pictures. I would bet that has something to do with your problem. Hope that is it. Simple replacement or fix
I installed a shift repair kit a couple years ago. It came with the pivot pins and I installed them. They were a tiny bit smaller diameter than the existing pins, so they didn't fit tightly into their bores. It's very possible they could fall out. I used a hose clamp to wrap around the tower / pins and hold them in place.
Well guys, I'm gonna pull the transmission out this week because I think it will be easier than pulling my interior. Once I get it on the bench and get the cover off, I'll be able to decide if I want to repair this transmission or replace it with a used ZF5. I think the ZF is a better transmission anyways, but we'll see once I get this one out and apart.
