Top Tier Diesel Fuel
I have been saying for years that low quality US diesel needs additives for various reasons and often get a response "today's trucks are made to run on this fuel". I knew that was not true, or at least not optimal as US diesel often does not meet the minimum standards suggested by the Engine Manufacturers Assoc. Now there is a push by auto manufactures for Top Tier diesel fuel in addition to Top Tier gasoline.
https://www.fuelsandlubes.com/fli-article/top-tier-diesel-standard-to-improve-operability-and-longevity-of-diesel-engines/
I found another article that indicates Top Tier diesel will be available on a by station basis due to availability in various markets
https://www.cspdailynews.com/fuels-n...-diesel-debuts
I would pay the extra few cents a gallon. I always throw PM-22 in my tank it's a PIA and I am not a fan of driving to empty. Actually, given the cost of the PM-22 it may wind up being cheaper for the better fuel. There is a pretty big logistical issue though, for stations that only have 1 diesel tank providing 2 grades of diesel fuel will be an issue.
I don't think you will need to worry about only one diesel tank. This is not "premium" diesel where you have a choice. I believe it is like the gasoline; it is either Top Tier or it isn't. For example; all grades of gasoline at an Exxon or Mobil station are Top Tier whether you pump 87, 89 or 91/93 octane. If the diesel pump is labeled Top Tier, that is all there is. However, just because it is an Exxon station doesn't mean the diesel fuel is Top Tier since the diesel supplier may not have it available. And "premium" diesel may not meet Top Tier requirements as Top Tier requires special filters and a water removal system.
Received 6,622 Likes
on
I have been saying for years that low quality US diesel needs additives for various reasons and often get a response "today's trucks are made to run on this fuel". I knew that was not true as US diesel often does not meet the minimum standards suggested by the Engine Manufacturers Assoc. Now there is a push by auto manufactures for Top Tier diesel fuel in addition to Top Tier gasoline.
Thanks for posting up, Ski. Since the link won't let me copy and paste a section, I'll have to write it myself. For the same reasons I use my additive, I'm currently at just under 32k miles and running like a beast, the 4 main criteria which seperate Top Tier diesel from the general quality requirements of diesel/biodiesel in the USA:
1) reduction of injector deposits though the use of a detergent additive package;
2) increased lubricity to reduce component failure;
3) a reduction in water and particulate contamination;
4) improved fuel stability.
The improvements are to made with the use FUEL ADDITIVES and filtration requirements.
So apparently guys like me are not the only ones who do not trust the quality of ULSD. I just don't understand the concept of how buying it from a station that sells a lot of it will guarantee the quality of fuel without testing it or without looking at it in a clear container. I'm just not the type to go under the truck every tank, every week or every month to drain the valve of the DFCM. If the diesel fuel is so good here in the US, why would Ford put a drain at the bottom of the lift pump? Why would they make additives? Why would anyone make additives?
Received 1,445 Likes
on
I understand no additives in the sewer because it is not needed. But when the engine manufacturers say the fuel needs improvement, why ignore it>
[QUOTE=Troy Buenger;18209429]Exxon Mobil Diesel Efficient is probably already Top Tier diesel. It's currently being phased in. I've been running it for ~ 1 month now and noticed reduced regen frequency.
/QUOTE]
Exxon/Mobil is not yet listed on the Top Tier diesel site, but they are for gas. And while they may be selling Synergy diesel somewhere, it is supplied by Irving Oil here in Vermont and the delivery driver said there is no difference and no additives for Mobil. I watched the 3 clips where they tout the name Synergy, but don't say what is different other than user testimonials. I am jot disputing anything, but want to know more and where it is sold, because it is not here in Vermont. As of now, Synergy diesel is neither certified Top Tier, nor is it sold universally.
Someone said if additives make it better, wouldn't producers already be putting it in their diesel. Clearly, not for years and not yet. Is there any value, clearly yes if the testimonials are to be believed.
/QUOTE]
From the Synergy web site:
What is Synergy Diesel Efficient fuel, and how does it differ from regular diesel?
Synergy Diesel Efficient diesel fuel was developed in the same laboratories as our racing fuels. It has been engineered to improve fuel economy (2% on average*), boost engine performance, reduce maintenance and provide cleaner emissions.
*Fuel economy improvement is based on Synergy Diesel Efficient compared to unbranded diesel fuel without detergent additive. Vehicle testing showed an average fuel economy improvement of 2 percent. Actual benefits will vary depending on factors such as vehicle/engine type, driving style and diesel fuel previously used.
Just for the record, I am a fan of Mobil Top Tier gasoline as my 2011 F150 Ecoboost got better mileage with it. So I am excited about better diesel fuels finally being developed.
on
So far, only Costco and Fast Stop are the only Top Tier licensed brands and that is on a by station basis. Costco says all new diesel fuel installations will be top tier.
