Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
F100wish build thread
Old 09-21-2018, 10:49 AM
F100wish's Avatar
F100wish
F100wish is offline
Well the registration hurdles are past and I have the 56 registered in Manitoba. Sheldon from BTB trailer rentals brought it here for me and was awesome, highly recommend him! This is what I have planned:
1) 351W/AOD (have this already). 351W is from an 88 F150 and I will convert it to simplicity ie. carb, shorty headers, and Vintage Air. The engine will be undergoing a quick refresh and the AOD had 2,000 km since its rebuild (from a 86 E-150).
2) TCI coil spring IFS, and rear parabolic spring kit. Not sure about the 2 inch drop spindles - could use some advice here. TCI 351W motor mounts and frame master cylinder.
3) Champion rad and need to convert diff to posi - not sure yet if it is a 8 or 9 inch - the truck is 40 minutes from my home so I only get to work on it once a week or so. I do work on what I can bring home.
4) Trying to decide between Ford Escape power seats or having the bench reupholstered like the Glide benches.
5) Dakota digital gauges, ?power windows, Ididit column with column shift
6) paint it primer grey
7)Vintique Series 62 rims - 15 inch with 235/75 like Darcy Dubuque's truck.
8) Rear gas tank - anyone do the 22 gallon Mustang tank install?
9) American Autowire kit
That is about it for now.
Hood and fenders in the box
Yup gold leaf on the Ford logo, hood scoop is going
Passenger fender and inner fender are stripped and ready for straightening
Old 09-22-2018, 08:15 PM
51dueller's Avatar
51dueller
51dueller is offline
Don't trash that hood scoop. It looks like a factory Big Job one and are somewhat uncommon. You shouldn't have a problem finding someone interested in it, if your not going to use it.
Old 09-23-2018, 02:25 PM
F100wish's Avatar
F100wish
F100wish is offline
I have this hood scoop. This was a F700 I think.
Old 09-23-2018, 02:32 PM
F100wish's Avatar
F100wish
F100wish is offline
I have this hood scoop but mine it has reliefs for the center hood line on the 56. Thanks 51Dueller I will definitely be looking to selling it to someone who could use it for their truck.
"Yes, they were functional.* They were only on the Big Job trucks, F800 / F900 and larger.* There was a round hole ( approx 4" in diameter ) cut in the hood under the scoop.* A formed metal air duct attached to the carburetor and ran up to just under the hood, with a gasket of sorts to seal the assembly to the hood when closed. Their scoop was mounted through the hood with (6) 10-24 studs and nutted on the back side.** The scoops and the scoop grille are a diecast metal construction.* The grille was chromed from the factory. To my knowledge, the was not any water diverter* in the scoop assembly, but the air duct had a cable operated plate to close off the air flow for some reason when operating.* I have only seen pictures of the hood and air duct assembly.** There are exploded drawings in most 56 parts manuals from Ford." (Copied from post by 53Ford senior member Feb 2003)
Old 09-23-2018, 03:00 PM
yamagrant's Avatar
yamagrant
yamagrant is offline
Lookin good wish. What part of the city are you in? I may be interested in the scoop.
Old 09-23-2018, 08:51 PM
F100wish's Avatar
F100wish
F100wish is offline
Hood scoop
i am in south st vital but the truck is north of wpg can let you know when I have the scoop off.
Old 09-24-2018, 11:54 AM
F100wish's Avatar
F100wish
F100wish is offline
Old 09-24-2018, 03:29 PM
yamagrant's Avatar
yamagrant
I'm in West St Paul. Inside the North Perimeter.
Old 09-26-2018, 08:01 PM
F100wish's Avatar
F100wish
F100wish is offline
Wire wheeled the other side inner fender and the driver's fender. They are in pretty good shape with the usual pinholes above the headlights on the fenders.
Not as much bondo on this side but has a good dent on lower front.
Cleaned up nice.
Old 10-05-2018, 12:15 PM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
Received 1,340 Likes on 1,102 Posts
Hi Rob, you have a pretty nice project going.
I had my inner fenders, air deflectors, grill, rad cradle and other front end parts sandblasted then primed and painted.
Old 10-08-2018, 03:57 PM
F100wish's Avatar
F100wish
F100wish is offline
Wire wheel was humming today. Front lower valance is too far gone, will have to get a new one.
Rad valance is cleaning up nice
Started with this...
Old 10-19-2018, 09:54 AM
F100wish's Avatar
F100wish
F100wish is offline
Old 10-19-2018, 09:57 AM
F100wish's Avatar
F100wish
F100wish is offline
Originally Posted by F100wish
Will replace floors even though rust is not all the way through they are getting a little thin. Will keep brace and weld in front halves and rear section. Cab not off of frame yet.
Old 11-05-2018, 08:01 PM
F100wish's Avatar
F100wish
F100wish is offline
Rear diff is out and off for a rebuild. It had 3.96 gears so I opted for 3.50s instead to help keep rpms down at highway speeds.
Will take some work getting the front leaf spring pin out, it is in there good!
Heading off to the driveline shop for rebuild.
Old 11-08-2018, 04:27 PM
F100wish's Avatar
F100wish
F100wish is offline
Polishing up the emblems, the grill emblem doesn't look so good. Anyone have a 1956 L side F100 side hood emblem? I only have the R side. I will repaint the red and black parts later.
Quick Reply: F100wish build thread
