Setup/info not to excellent
go at red battery light on my console . 2019 f-450 6.4
ran setup/ info and when it got to charging system is passed it.
But, voltmeter battery voltage said 10 volts
odbc scanner had battery at 10 and alterbatorvat 10
so basically the setup/info charge system pass report just means the setup/info check just went past it.
Skip the obd test and do a dvom test for a solid comparison.
I don't ever trust just one resource.
Many years a professional mariner, I was always trained, if all else fails.........trust your compass.
That is and was always good advice, until one of my engineers left his magnetic tip screwdriver behind the binnacle to roll with the ship.
Let's just say we went places.
Have you pulled the alt yet and had it bench tested off the truck? Just a good bench mark to see if we have alt problems or something integral in a harness going south.
Denny
Denny
63' f100
11-27-2010 09:32 PM
Ballerforlife911
16
02-18-2010 06:46 PM
