96 f150 5.0 running rough
Old 09-20-2018, 04:31 PM
Michael Carter
Michael Carter is offline
Michael Carter is starting off with a positive reputation.
Iíve sent my truck to multiple shops had it diagnosed and was told different things had the transmission checked out and itís top notch. I did a tune up, had the intake manifold resealed, replaced the fuel pumps, fuel filter, fuel pressure regulator, Iíve ran almost every fuel treatment you can imagine through it, replaced the EGR valve. The mechanics told me I had good compression and all 8 cylinders were firing. When driving after itís warm it likes to chug especially up hills
it spits an spudders at low rpmís. And it seems to me itís low of power. Itís kicking my butt lol need help
Old 09-20-2018, 04:42 PM
Binkowski's Avatar
Binkowski
Binkowski is online now
Binkowski is starting off with a positive reputation.
Let's start with the basics, is your Check Engine Light on and if not,have you checked for stored codes? Best place to start.
Old 09-20-2018, 04:48 PM
Michael Carter
Check engine light doesnít work had it checked numerous times and all it threw was abs and #6 cylinder misfire checked it out and the spark plug wasnít gapped right after I gapped it the code was gone after re checking
Old 09-21-2018, 11:27 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.'89F2urd has a very good reputation on FTE.
Check fuel pressure under load. Also see if the pressure immediately drops when the engine (or pumps stop, engine off) is turned off. If it bleeds off quickly, you may have a leaky injector.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
