Motorcraft Ignition Wire Kit
Hey all,
I've got a 1993 F150 with the 302 V8. I am restoring it and recently got new ignition wires, distributor cap, rotor.
I installed the ignition wires one at a time replacing what was on there before. I got it all together and it seems to run quieter than before with possibly less power? Maybe there were performance wires on there before...
Anyways, I tried to line up the length of the wires as best I could to figure out which wire went where. I noticed there were numbers on the boots of the wires. This makes me think that these numbers are used to indicate which plug they go to? Any thoughts?
I also had an extra ignition wire in the Motorcraft box. That put me at a total of 10 wires. Any thoughts?
Thanks all
Thanks all
The numbers were 3 and 4 digits that looked like electrical ratings... I'll see if I can take a photo when I get out to the truck. None of the numbers matched up with numbers on the old wires I pulled off.
Spacers are in the mail... looking forward to tidying them up. I have read you don't want 1,3 and 5,6 next to each other.
Not sure if it has been changed to roller cam. I'll double check to make sure that's how the wires are set up. Recently took it out to the grocery store, about a mile down the road, and right before pulling into a parking spot truck lost all power, lights and everything. Fired up eventually and made it home... did some poking around and looks like it could be the ignition module.. any thoughts?
