Blew my 7.3 in need of leads to a forged short block - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 09-18-2018, 05:50 PM
Jmudweiser
Jmudweiser is offline
Jmudweiser is starting off with a positive reputation.
My goal is to build a 500 hp heavy tow (20,000 lb) motor.
list recommended parts list, and turbo choice. I had a KC Turbo that failed after 2 years, w a stock motor w tunes.
i did have a T500 pump too.
Old 09-18-2018, 06:08 PM
Sous's Avatar
Sous
Sous is offline
Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.Sous has a spectacular reputation.
That sucks, sorry for your trouble...
As for the turbo choice, nothing has proven to be better than a T4 (Carson Stauffer Diesel, Irate Diesel or homemade) and a Borg Warner SXE turbo of your choice.
I would encourage you to browse through a thread I created a little while back just after making my decision to go with the SXE and purchasing all of the required parts.
Link below, and good luck to you... I will be following along for sure.
https://www.ford-trucks.com/forums/1...been-made.html
Old 09-18-2018, 06:16 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
2002 F550 cab/chassis is rated at 24,500# trailer tow weight with a stock 7.3...why the 500hp?
can achieve a reliable motor with turbo mentioned above, them 80% injectors and a 1023 tunes..(not a fan of tunes, but thats me)
Old 09-18-2018, 06:18 PM
The Brad
The Brad is offline
The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.The Brad has a great reputation on FTE.
238/80 injectors, Borg Warner 366/74/1.0 turbo, T4 mount, Head studs, valve springs, higher volume fuel pump or dual stock pumps and tuning.
Old 09-18-2018, 06:53 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.pirate4x4_camo has a spectacular reputation.
Since you are in CA I’d think you would use a stock turbo so you can get the vehicle registered.
also being in CA with our 55 MPH tow speed limit I’d say a stock motor will tow 20k just fine and likely last much longer then a 500hp setup.
maybe a better question is will a 500hp Motor pass CA smog every 2 years ?
Old 09-18-2018, 08:48 PM
Jmudweiser
Great link! And thank you.
I suppose Iím alike, its not 500 hp itís a reliable tow rig, set up correctly. Although instead of taking big grades at 25 mph at 2500 rpm Iíd like to go 65.
Old 09-18-2018, 08:51 PM
Jmudweiser
I have read a lot on 238/80 injectors being a great heavy tow injector.
Being in CA, Iíll have to stick with the KC38R tho
Old 09-18-2018, 09:08 PM
Wesley Green's Avatar
Wesley Green
Wesley Green is offline
Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.Wesley Green has a good reputation on FTE.
Hate to burst your bubble, but a KC38R will fail inspections in CA, many threads on that as well. Has to say Garret on the housing, so you are stuck with stock housing or Garret 38R
Old 09-18-2018, 09:44 PM
Nicmike's Avatar
Nicmike
Nicmike is online now
Veteran Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
You could always get out of California, do whatever you want with your truck, and never be subject to that craziness again...
Old 09-18-2018, 09:54 PM
timmyboy76's Avatar
timmyboy76
Originally Posted by Wesley Green View Post
Has to say Garrit on the housing,
he'll fail with that turbo as well..
Old 09-18-2018, 10:16 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
Always one in the group
Old 09-18-2018, 10:30 PM
Jmudweiser
Originally Posted by pirate4x4_camo View Post
Since you are in CA Iíd think you would use a stock turbo so you can get the vehicle registered.
also being in CA with our 55 MPH tow speed limit Iíd say a stock motor will tow 20k just fine and likely last much longer then a 500hp setup.
agreed, I just need it faster than 25 up a grade.
Old 09-18-2018, 10:31 PM
Jmudweiser
Id love too lol, but business is here.
Old 09-18-2018, 10:34 PM
Jmudweiser
[QUOTE=Wesley Green;18202512]Hate to burst your bubble, but a KC38R will fail inspections in CA, many threads on that as well. Has to say Garrit on the housing, so you are stuck with stock housing or Garrit 38R[/QUOTE
do to its more stock look than a t4 mount ive passed with h no questions thankfully.
Old 09-18-2018, 11:27 PM
pirate4x4_camo
I do 40-45 over the steepest parts of Donner Pass towing 15k and am basically stock. Iíve towed it 100k miles all over the western USA and have never been slowed to 25.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
