1948 Ford Truck wiper linkage
So I am just missing the 17562 apparently. I had it rebuilt at Fickens and works great. I just obviously misplaced this grommet part. I will have to go looking to make something work. So grommet over the shaft, bar slides over the grommet, clip holds it on, dial wire threads into clip. It's always the little parts!!!
The bronze nut/bushing should turn freely on the shaft. I believe it is an oilite bronze. It is hex shaped so the rubber grommet will fit tightly on the nut and turn the bronze nut on the shaft as the wipers move. The rubber does not turn on the nut and does not need to be lubed. A little light oil on the shaft for the inside of the hex bushing wouldn't hurt anything.
Mark
Mark
Rogue_Wulff
02-05-2011 07:33 PM
WillTX
09-11-2009 05:26 PM
Cannon51
12-04-2006 05:16 PM
