5.4 3v whipple 2.3 TPS install problem - Ford Truck Enthusiasts Forums
Old 09-18-2018, 09:57 AM
Shawn_Laughlin
Shawn_Laughlin is offline
Shawn_Laughlin is starting off with a positive reputation.
I have an 04 F150 5.4 3v and whipple 2.3l amd I think the model is a 140ax. My problem is Iíve been having problems with bogging since I built the engine and installed blower and I remember before with old engine it would surge and Iím thinking itís been the tps all along. Sometimes while driving and getting up to highway speed it will rev up and I can feel the extra power and then Roma drop and itís a dog. Itís not the transmission bc I just rebuilt it myself and did the same thing before as now.
I tried to replace the tps a few years ago and the new one that ford sells and auto parts house are a new design and will not fit bc itís too tall and hits the blower. Thereís just not enough clearance and from what Iíve seen ford has changed it again and itís even taller. Has anyone had this problem and no a way around it besides buying one from a junk yard?
Old 12-26-2018, 09:04 AM
MeanGene1's Avatar
MeanGene1
MeanGene1 is offline
MeanGene1 is starting off with a positive reputation.
Shawn, I have a similar setup, 2004 with the Whipple. There is an adapter that is used for the GT500 90mm TB upgrade that you might be able to use. It will rotate the TB 15 degrees and may give you enough room for the TPS. However, I have never used the adapter so you will have to do your own research on it.
https://www.steeda.com/ford-racing-5...-9474-m50.html
Old 12-26-2018, 01:24 PM
Shawn_Laughlin
Thank you so much MeanGene1. I will definitely look into that
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
