E350 1992 Parking brake Pedal goes to floor
hi there,
my Name is Marc from Germany. I have a rv on a e350 1992 Ford.
I hope you can help me.
My my Parking brake Pedal goes to the Floor.
If i remove the spring between the Equalizer and Frame,
it Works great but Then the brake blocked After i pull down the Pedal, although i adjusting the star-wheels.
the cable have All the way no adjuster.
Is it necessary to loosen the star-wheels completely to Start an new adjustment.
Maybe you can give me some helpful hints.
Thank you very much
Marc
Thank you very much
Marc
I've not worked on the parking brake systems but if you don't find much help here try this sub-forum maybe: Brake Forums
Hope this is easily fixed or repaired Marc!
You don't need this tread moved as someone may yet come along with advice or experience here. I'd create another separate post in the brakes forum maybe referencing this one. It can be helpful having different eyes looking at a single issue.
While your van is the next generation from my 1989 model, I think the procedure is the same.
The star wheels on the wheels adjust the service brake only. They do have to be properly adjusted to set up the parking brake later. Adjust them until you just begin to drag then back off a couple clicks.
For the parking brake pedal to go to the floor, you either have a broken part in the pedal assembly, a broken parking brake cable ( there are 3, the front, and a left and a right rear cable) or the parking brake itself is badly out of adjustment. The rod going to the equalizer bar is threaded, and it there that you adjust the parking brake. Apply the parking brake about 4 clicks on the pedal, and adjust the rod until the wheels begin to drag. Release the parking brake pedal and check the wheels turn free
Jeff
Jeff
Google ford e350 parking brake adjuster, there are a lot of images. This one is basically what is under my motorhome, and turning the nut adjusts. Perhaps your later generation van uses a different system
https://www.bing.com/images/search?v...=65&ajaxhist=0
If the cable is slack, there are universal cable adjusters available that can take up slack
Jeff
Jeff
seventyseven250
2009 - 2014 F150
13
05-22-2017 09:23 PM
clarkbre
05-13-2014 11:58 PM
Stingray42
03-15-2004 03:53 AM
