6.2L V8 Discuss the 6.2L V8
Coolant Flush
Old 09-17-2018, 11:50 PM
GlenPxC's Avatar
GlenPxC
GlenPxC is offline
Coolant Flush
Just bought my first super duty, 2011 f350 6.2 with 141000 miles. The previous owner had either used green or a universal coolant. So one of the first things I did was flush the system and refilled with ford orange. I only opened the drain valve on the radiator system since the plug on the block was very rusty and I wasn’t about to try to get that out. I drained, filled with distilled water, ran the truck with heat on, then drained again. I repeated this until all water coming out was clear and a few times after that.
There wasn’t a coolant capacity stated in the owners manual and even the ford dealership couldn’t find it in there computer system. I found a few “specs” online stating the system took somewhere between 5-6 gallons. I know that a decent amount of water stays in the block and heater since I didn’t pull the engine plug. After the final drain, I was able to put 3 gallons of concentrate into the system until it met the full line. So if the system takes about 6 gallons then I should be okay as far as having a 50/50 mixture? I bought one of those cheapy floating ball testers and 4 out of 5 floated which according to the scale meant I am good up to -25 degrees Fahrenheit
Old 09-18-2018, 06:53 PM
Barney1234's Avatar
Barney1234
Barney1234 is offline
Just curious, due to my ignorance, but a few months ago I picked up some coolant for my son's 2008 F150 4.6l and Ford had both orange and green. What is the difference? I can't recall, but I believe they told me to get the green.
Old 09-18-2018, 07:23 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
You should be fine with that concentration. The ford specialty orange is the same as dexcool.
To the above regarding the F150, the dealership should have sold you ford gold.
Old 09-18-2018, 07:24 PM
Barney1234's Avatar
Barney1234
Yeah, that was it! Ford Gold. I couldn't remember.
humphrey169
11-13-2017 08:12 PM
jajones1988
1999 to 2016 Super Duty
04-22-2014 11:51 AM
ScotF150
Large Truck
10-20-2012 02:12 PM
maa139
11-21-2004 09:05 AM
umdstang
1997 - 2003 F150
06-16-2004 09:28 PM
Quick Reply: Coolant Flush
