Pink Wire Fire!
Have not been behind many dashes of the pickups, but the Broncos were done in different ways over the years.
On some, the Red w/green wire would come out of the switch to a small push-connector, where it transitioned to the resistor wire for most of the rest of the way to the firewall.
On others, the resistor wire was routed all the way to the ignition switch in one piece, with no connector to allow you to easily change out a burned up resistor wire.
I've seen variations too, where both wires were spliced to the same contact point on the switch. This was mostly on later trucks with electronic ignitions I think. Where the resistor wire ran to the ignition coil as always, and the new Red w/green wire powered up the Dura Spark ignition module. Along with a few other keyed items too, for some vehicles.
Probably other variations as well, but not sure.
In other words too, I'm not sure how yours was wired originally, but both colors are legit for your year. How they were originally connected at the switch is the question. Others that have fiddled with their switches more recently will know though.
Paul
Paul
Anyway, it's fun solving 50 year old wiring mysteries!
It may be what you're actually referring to is resistance type noise suppression plug wires, these result in a higher coil firing voltage. That's what it sounds like anyway. I can't really comment on what a book from 1979 may or may not have said without specifics. Maybe scan a pic of a paragraph or two and get it sorted out.
Or can it be figured out with other information based on your own particular components?
Just wondering how you figure out if your system is going to allow your trigger mechanism to see 3, 5, 8, or 10 amps.
Pigtail For Blade Style Ignition Switch! (
1 2 3)Seems like there would be more to it. Such as how much the unit itself "uses" or "blocks" by way of adding it's own resistance perhaps? Maybe as an electronic device that loss is minimal, so we're still looking at 9-ish amps flowing through the Ignitor with a 1.5 ohm coil?
Didn't think it was that simple, which is why I asked the previous questions. I'm aware of ohm's law, just didn't think it applied directly as-is in this case.
Thanks.
Paul
Grounding is really important. There are basic troubleshooting steps with a simple voltmeter where defects in corroded connections can be found easily, these will inhibit a good hot spark at the plugs in ways that are otherwise tough to diagnose. It's one thing to get a plug to spark in the open air but a totally different thing under high cylinder compression, a heavy load and high RPM. Even a defective ignition switch can cause all kinds of trouble or a poor distributor ground, and solenoids can fail in the primary too.
One thing that complicates the amps calculation a little bit is the coil is not "On" all the time so the current is actually somewhat less than Ohm's Law would indicate. For V8 the dwell is somewhere around 30° or about a 67% duty cycle. This is why leaving the key in the ON position without the engine running will tend to burn up and lunch the ignition coil after several minutes. Too much current flow. I use 14 or 14.5 volts as a baseline, something like that, not 12.6 nominal battery voltage.
I like to try and understand the "why" and "what" behind otherwise sometimes cryptic specs and instructions. Study the manuals and get a handle on what's really going on and you can usually make your own informed decisions without depending on thirdhand speculation and wankery.
When electronic ignitions were introduced, the wire color stayed the same, but split off to power not only the coil, as in previous years, but the ignition modules and a few other things as well.
And yes, on older trucks the "method" changed, but the colors should have been consistent. Some years the Red w/green exited the ignition switch for a few inches, then became the Pink wire. Others the Pink ran right down to the switch connector directly.
Some of the spliced ones were one wire, while others had connectors so you could literally change out a failed resistor wire with little fuss. I went down to my local Kragen store (now O'Reilley's) and purchased a Standard Motor Products replacement Ford resistor wire that had that bullet connector. Ford dealer had one as well, but I don't think I have one. Still have the Standard one in a box somewhere because it turned out that I didn't need it after all.
So the wiring does vary by year, but the wire colors should be the same. Hopefully your Red w/green wire runs up to the ignition.
On most older Ford Ignition switches, the Green w/red and the Red w/green are the only two wires that are hot only with the key in the ON position. Whereas all the others (except for the Red w/blue) are hot in ACC and ON both.
Paul
