Towing milage in a headwind
Just got back from a fishing trip hauling my 5000 lb camping trailer from Ventura Co. to Bridgeport Calif. 365 mi each way. Desert and mountians. On the trip up averaged 10 mpg. Comming back I averaged 7.5 to 8 mpg with a direct headwind pretty strong. was only driving about 60 to 65 mph. Does this sound normal. Never experienced such low milage while towing before. Had a sway bar and WDH. Experienced very little sway probably because I was heading into the wind and drove in 5 th gear most of the way. Appreciate any imput.
Mileage looks fine, I just averaged 7.2 mpg with my 2018 3.5 max tow on a 2600 mile round trip to Texas. I was right at 18k GCW so right at the upper limit. I was towing 11.5k and had the truck weighed down with about 1500 lbs in tractor parts and passengers. Roughly 11 tanks of gas set me back just shy of 1300.00. So I do believe your mileage is decent. What year is your truck?
Towing in a headwind
Yes you are correct 2016 XLT 2wd super cab 3.55 rear. when I got closer to home and out of the desert my milage and speed improved. Thanks for the inputs.
Hi
Following this as I am thinking it is time to move on from my 2001 F250 4x4 Super Cab V10, I have a 23 Komfort travel trailer and fully loaded bed of stuff for camping including a Dirtbike. My mileage is around 7 at 65mph in CA. I was thinking of getting the F150 with 3.5l. But it does not sound like the mileage will be much if any better, am I reading this correctly.
my unloaded mileage is crap, like maybe 11.
Hi
You know that the statewide speed limit for vehicles towing trailers is 55 MPH. Right?
