8.6mpg pulling my 8000lb conventional travel trailer.
I drag a Voltage V3605 Toy Hauler. The dry weight listed from their specs say 13,260. We live just outside of Denver. In the last couple of years, we have dragged it to Glacier National Park, Yellow Stone (3x) and all the way dow to Corpus Christie Tx. We make several trips to the mountains through the year too. Sometimes not very often on summer fuel we average 10.5 on a good day but not likely. Most of the time it doesn't matter 8 to 9 MPG is all we see. Doesn't matter much if we are fully loaded or empty with only 1/3 water on board or less. When I head west through the mountains the MPG is typically down to 6 until we get to the flatter areas. We have actually been talking about downsizing to a lot smaller of a trailer, simply to cut the fuel bill because we use ours a lot.
A travel trailer has the aerodynamics of a brick and a toy hauler, with the large square rear, has the aerodynamics of a cinder block. All you can do is slow down and reconsider driving habits. Remember it ain't so much the shape of the front, but the shape of the rear, sub-sonic airplanes come to a point in the rear for a reason.
My experience is its not the weight of the trailer but the aerodynamics and how it is set up when pulling with a diesel. I have pulled a 6000lbs enclosed trailer that was "96 wide (12' tall) which got worse mileage than my 16000lb 5th wheel with a back hoe. Wind resistance trumps weight at those speeds in IMO. Any type of x wind just kills your mpg.
I got 12mpg on a recent 3000 mile round trip towing my 10K fifth wheel. One thing the OP didn't mention was speed. I tow at 62-64 mph because ST tires are only rated to 65 and because I feel it is safer. I use cruise control where appropriate which does less downshifting because it has a lighter touch than my foot. I also use Opti-Lube Summer Plus at full dose for cetane and lubricity, plus Enerburn for reduced soot and regens.
My 2011 Ecoboost got 9-10 mpg on the same trip.
I pulled my travel trailer about 1250 miles this week from Green Bay, WI to the Grand tetons, and only returned 8.6 mpg. It weighs a little more than 8000lbs and is thirty feet long. Hit some head winds in South Dakota and only got about 7.8mpg, but usually averaged about 8.9mpg with little wind. Cruise was set for about 67mph.
Does this seem normal?
My2011 Ecoboost averaged about the same with this trailer. And both this 6.7 diesel and my Ecoboost average about 19mpg empty on the hwy
my guess is you were going thru a regens cycle while going thru the mountains at some point.
Look at the Goodyear Endurance tires they came out with two year ago. They are rated at 85 mph.
I put these on my horse trailer last summer. I will tow at 70-75 mph. Even though most of the interstate freeways here in Utah have 80 mph speed limits and people are driving 80+ mph
My GN horsetrailer weighs in at 13,000 lbs loaded. But it could be empty at 6,000 lbs and I would get the same fuel milage. Wind resistance and rolling resistance have a higher effect than the weight.
And I get 10.6 when towing
The last tow from TX to CO wasn't heavy but the v nose cargo trailer (7' walls) was a heck of a wind block. My 2020 stayed in 9th most of the time only hitting 10th on occasion. Boost stayed 20-25 psi. Going up in altitude from 850' to 8500' doesn't help nor does the crazy a$$ wind in west Texas and on I-25 from Raton towards Walsenberg. Getting 9 mpg pulling a light load sucks but that's better than taking an extra 1.5 to 2 hours for the trip
I get around 10-11 mpg pulling my 5th wheel. It's not super heavy but it's tall and pulls hard. On a hot day, the old duramax couldn't pull it too fast without overheating. (common problem with that generation of motor). The 6.7 can pull it as fast as I want to go, and I recently put some Carlisle 10 ply 85 mph tires on the trailer, so I can do it without blowing up a tire.
It will be interesting to see what you get going home. You went from less than 1,000 feet elevation to some pretty high terrain.
Last year I towed my trailer through 46 states. Every trip from the midwest to the Rockies had unusually low mileage. Return trips were always much higher. Keep us posted.
davidkstyler
05-30-2012 09:40 AM
