2000 F-250 5.4 more power help - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-16-2018, 11:35 AM
eirk66
eirk66 is offline
eirk66 is starting off with a positive reputation.
Hey guys rebuilding my 2000 f250 5.4 spun a bearing on the crank just finished motor rebuild now trying to get more power out of it this time around.
Was looking to get a tuner for my truck was wondering what you guys suggest.
2000 Ford F-250 4x4 V8 5.4L
K&n cold air intake
Gibson headers
Air raid throttle body spacer
Lifted with 35in tires
What’s the most hp/tq tuner you have and
I live in California so not sure if I’d have to change back to stock tune for smog.
Thank you have a great day.
Old 09-16-2018, 12:01 PM
Juneaudave's Avatar
Juneaudave
Juneaudave is offline
Juneaudave is starting off with a positive reputation.
What kind of gearing do you have?
Old 09-16-2018, 02:13 PM
eirk66
eirk66 is offline
Stock 3.73s what’s the cost roughly to re-gear was looking at that in future tax return might due 17in rims 37 bfg a/t and re-gear
Old 09-16-2018, 02:29 PM
Juneaudave's Avatar
Juneaudave
There are quite a few threads regarding the costs...here is one from a few years back... 4x4 Gear Change Cost Moving from 3.73s to 4.30s might be a good long term strategy.
Old 09-16-2018, 08:28 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
With 35" tires at least 4.56, 4.88 would be optimal. Exhaust Y pipe, 5 star tune and you will have a peppy trucks, if thats not enough force induction is the only way to increase HP and TQ in a 5.4.
Old 09-17-2018, 06:46 AM
02TB250's Avatar
02TB250
02TB250 is online now
02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.02TB250 has a great reputation on FTE.
Re gear the truck, 4.88s if your planning on 37s. After that you can take a look at a tuner or other options. Best bang for your buck is gears. Tuner is not as effective on the 2v/4r100 trucks as it is on the later 3v or diesels
Old 09-17-2018, 03:26 PM
eirk66
eirk66 is offline
Was thinking about doing flex a lite electric fans to clear up restriction from stock have any of you done this?
Thank you gentlemen appreciate the help.
Old 09-17-2018, 04:03 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
Ok take this as you want, I've been down this road already with my 5.4. Throw that intake and throttle body spacer in the trash, spend the money and get custom long tube headers made with a free flowing ypipe if you want real power. You'll need 4.88 years for 35" tires MINIMUM and with 37's go to 5.13 gears. A tuber wont help anything on these 2valve motors except altering the shift points higher other than that no power gains at all. Your best bet also is to add the newer high flowing PI heads and intake
Old 09-17-2018, 04:05 PM
SuperDutyScaler
And if you really want power install the 4.6 power adder for mustang's but order parts designed for low end power not high rpm. Then buy 4.6 intake spacers and bolt on a 4.6 intake from a mustang and your gonna have to get dyno tuned
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
