2019 F 250 max comfortable towing ?
I have the F250 gasser on order and we're search for our Toy Hauler TT now. The Max tow capacity is listed at 12.5 k # and payload at ~3380#.
When thinking about how much I can actually tow comfortably , do I need to consider how much weight I will have in the truck and do I subtract that from the towable weight?
For example, if my toy hauler has a UVW at 9.5 k # and I put 2k# in it for a total of 11.5 k , that's still 1k under the max tow capacity. Do I need to consider how much weight I put in the truck ?
Is that max tow capacity , 12.5k , a number thats really pushing it or is it a realistic number?
Thanks for any help
Thanks for any help
These threads usually get a lot of different opinions but I think you’re fine. Most of the trailer weight will be on it’s axles. A small portion (10 to 15%) will actually be on the tongue so it sounds like you’ll have plenty of cushion for both payload and trailer weight. Are your max towing and payload numbers from your specific truck or are they just the advertised numbers? Numbers for a given truck can vary substantially from the generic spec sheet due to config and options.
Something seems off with those numbers. How did you get that payload number? Was the truck ordered with standard or reduced GVWR? You subtract all weight added to the truck from the GVWR including curb weight. Take curb weight, passengers and cargo and subtract from GVWR. Then figure your hitch weight and subtract that. You should be within the GVWR at this point if not you need to shed weight. Your biggest problem is your GCWR is only 19.5k (based on your indicated 12.5k tow capacity, which indicates 3.73 axle ). There is no way to max out the GVWR of either the truck or the trailer as you will exceed capacity.
Received 6,677 Likes
on
Changing an order is allowed up to a certain point and then it's locked by Ford. My original order was locked by the time I found an error. I had to reorder.
Agreed! OP, if a 5th wheel is ever in your future then the F-350 is a much better option. I have an 11K bumper pull toy hauler that my F-350 (with the 6.7L) pulls well. The gas engine wouldn't do nearly as well here in Colorado. I would HAVE to go with the 4.30 gears to try and make up for the gas engine. The diesel is a dream to tow with. The transmission in the F-250 gas truck might not do as well in the mountains as the 6r140 does.
Well I had to draw the line somewhere with my budget, so diesel is out for me ( for now ). I live on the east coast but do plan to travel out west at some point.
I looked into the 250 vs 350 ( gas engine ) differences. ( Lots out there in google land !!! ) Doesn't seem like 1k worth of change in tow / load capacity and GVWR. I could be wrong as I'm just learning to decipher the listed specs Ford gives.
(see next post )
