1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
c notch
Old 09-15-2018, 02:03 PM
kiwiguy's Avatar
kiwiguy
kiwiguy is offline
c notch
I guys I have a 62 unibody where is the best place to buy a c notch kit from prefer bolt in, also I have a crown vic front sub frame would like to lower the front any ideas on where to buy lower springs
cheers kiwiguy
Old 09-21-2018, 06:59 AM
dman2008's Avatar
dman2008
dman2008 is offline
Front options. Depending on budget.
Crown vic lowering springs are available from Eaton Detroit and lower it 1.5-2" https://www.eatondetroitspring.com/a...rown-victoria/
or get some coil overs from multiple vendors. https://www.speedwaymotors.com/RideT...ic,338405.html
Rear Options
C Notch Options.
https://www.performanceonline.com/19...-c-notch-kits/
Or go buy some 3/16" flat bar approx 6" wide and get it cut to length or buy a 10' piece and cut to size and shape accordingly and also use it to build boxing plates.
You will also require shorter shocks on the rear once you get your rear axle flipped or spring packs modified.
D
shrekau
09-05-2012 06:03 AM
Ken2600
07-27-2008 08:45 PM
lucky no. 7
01-22-2007 09:57 AM
NateDog07
03-15-2006 10:23 PM
OneFine69
11-30-2004 09:23 PM
Quick Reply: c notch
